标题: Spring Boot 与 Kotlin 整合MyBatis(1) [打印本页]
作者: look_w    时间: 2019-3-4 20:53     标题: Spring Boot 与 Kotlin 整合MyBatis(1)
创建项目,在build.gradle文件中引入依赖
    compile "org.mybatis.spring.boot:mybatis-spring-boot-startermybatis_version"
    compile "mysql:mysql-connector-javamysql_version"
完整的build.gradle文件
    group 'name.quanke.kotlin'
    version '1.0-SNAPSHOT'
    buildscript {
        ext.kotlin_version = '1.2.10'
        ext.spring_boot_version = '1.5.4.RELEASE'
        ext.springfox_swagger2_version = '2.7.0'
        ext.mysql_version = '5.1.21'
        ext.mybatis_version = '1.1.1'
        repositories {
            mavenCentral()
        dependencies {
            classpath "org.jetbrains.kotlin:kotlin-gradle-pluginkotlin_version"
            classpath("org.springframework.boot:spring-boot-gradle-pluginspring_boot_version")
    //        Kotlin整合SpringBoot的默认无参构造函数,默认把所有的类设置open类插件
            classpath("org.jetbrains.kotlin:kotlin-noargkotlin_version")
            classpath("org.jetbrains.kotlin:kotlin-allopenkotlin_version")
    apply plugin: 'kotlin'
    apply plugin: "kotlin-spring" // See https://kotlinlang.org/docs/refe ... ing-compiler-plugin
    apply plugin: 'org.springframework.boot'
    apply plugin: "kotlin-jpa"  //https://stackoverflow.com/questions/32038177/kotlin-with-jpa-default-constructor-hell
    jar {
        baseName = 'chapter11-6-5-service'
        version = '0.1.0'
    repositories {
        mavenCentral()
    dependencies {
        compile "org.jetbrains.kotlin:kotlin-stdlib-jre8kotlin_version"
        compile("org.jetbrains.kotlin:kotlin-reflect{kotlin_version}")
        testCompile "org.springframework.boot:spring-boot-starter-test:$spring_boot_version"
        testCompile "org.jetbrains.kotlin:kotlin-test-junit:$kotlin_version"
    compileKotlin {
        kotlinOptions.jvmTarget = "1.8"
    compileTestKotlin {
