标题: Angular Directive 详解(4) [打印本页]
作者: look_w    时间: 2019-3-8 18:46     标题: Angular Directive 详解(4)
directive 实例讲解
下面的示例都围绕着上面所作的参数说明而展开的。
    directive声明实例
    // 自定义directive
    var myDirective = angular.modeule('directives', []);
    myDirective.directive('myTest', function() {
        return {
            restrict: 'EMAC',
            require: '^ngModel',
            scope: {
                ngModel: '='
            template: '<div><h4>Weather for {{ngModel}}</h4</div>'
    // 定义controller
    var myControllers = angular.module('controllers', []);
    myControllers.controller('testController', [
        '$scope',
        function($scope) {
            $scope.name = 'this is directive1';
    var app = angular.module('testApp', [
        'directives',
        'controllers'
    <body ng-app="testApp">
        <div ng-controller="testController">
            <input type="text" ng-model="city" placeholder="Enter a city" />
            <my-test ng-model="city" ></my-test>
            <span my-test="exp" ng-model="city"></span>
            <span ng-model="city"></span>
        </div>
    </body>
    复制代码
template与templateUrl的区别和联系
    templateUrl其实根template功能是一样的,只不过templateUrl加载一个html文件,上例中,我们也能发现问题,template后面根的是html的标签,如果标签很多呢,那就比较不爽了。可以将上例中的,template改一下。
        return {
            restrict: 'EMAC',
            scope: {
                ngModel: '='
            templateUrl:'../partials/tem1.html'   //tem1.html中的内容就是上例中template的内容。
    复制代码
scope重定义
    //directives.js中定义myAttr
    myDirectives.directive('myAttr', function() {
        return {
            restrict: 'E',
            scope: {
                customerInfo: '=info'
            template: 'Name: {{customerInfo.name}} Address: {{customerInfo.address}}<br>' +
                      'Name: {{vojta.name}} Address: {{vojta.address}}'
    //controller.js中定义attrtest
    myControllers.controller('attrtest',['$scope',
        function($scope) {
            $scope.naomi = {
                address: '1600 Amphitheatre'
            $scope.vojta = {
                address: '3456 Somewhere Else'
    // html中
        <div ng-controller="attrtest">
            <my-attr info="naomi"></my-attr>
        </div>
    </body>
    复制代码
其运行结果如下:
    Name: Naomi Address: 1600 Amphitheatre      //有值,因为customerInfo定义过的
    Name: Address:                              //没值 ,因为scope重定义后,vojta是没有定义的
