标题: iOS 中常见的几种锁-代码示例(4) [打印本页]
作者: look_w    时间: 2019-3-10 14:27     标题: iOS 中常见的几种锁-代码示例(4)
4. 条件锁
4.1 NSCondition
    NSCondition 的对象实际上是作为一个锁和线程检查器,锁主要是为了检测条件时保护数据源,执行条件引发的任务。线程检查器主要是根据条件决定是否继续运行线程,即线程是否被阻塞。
    NSCondition同样实现了NSLocking协议,所以它和NSLock一样,也有NSLocking协议的lock和unlock方法,可以当做NSLock来使用解决线程同步问题,用法完全一样。
    - (NSMutableArray *)removeLastImageNSMutableArray *)images {
        if (images.count > 0) {
            NSCondition *condition = [[NSCondition alloc] init];
            [condition lock];
            [images removeLastObject];
            [condition unlock];
            NSLog(@"removeLastImage %@",images);
            return images;
        }else{
            return NULL;
    复制代码
    同时,NSCondition提供更高级的用法。wait和signal,和条件信号量类似。
    NSCondition和NSLock、@synchronized等是不同的是,NSCondition可以给每个线程分别加锁,加锁后不影响其他线程进入临界区。这是非常强大。
    - (void)lock10 {
        self.conditionArray = [NSMutableArray array];
        self.xwCondition = [[NSCondition alloc] init];
        dispatch_async(dispatch_get_global_queue(DISPATCH_QUEUE_PRIORITY_DEFAULT, 0), ^{
            [self.xwCondition lock];
            if (self.conditionArray.count == 0) {
                NSLog(@"等待制作数组");
                [self.xwCondition wait];
            id obj = self.conditionArray[0];
            NSLog(@"获取对象进行操作:%@",obj);
            [self.xwCondition unlock];
            id obj = @"极客学伟";
            [self.conditionArray addObjectbj];
            NSLog(@"创建了一个对象:%@",obj);
            [self.xwCondition signal];
    复制代码
4.2 NSConditionLock
    - (void)lock11 {
        NSConditionLock *conditionLock = [[NSConditionLock alloc] init];
        NSMutableArray *arrayM = [NSMutableArray array];
            [conditionLock lock];
            for (int i = 0; i < 6; i++) {
                [arrayM addObject(i)];
                NSLog(@"异步下载第 %d 张图片",i);
                sleep(1);
                if (arrayM.count == 4) {
                    [conditionLock unlockWithCondition:4];
        dispatch_async(dispatch_get_main_queue(), ^{
            [conditionLock lockWhenCondition:4];
            NSLog(@"已经获取到4张图片->主线程渲染");
            [conditionLock unlock];
    复制代码
4.2 pthread POSIX Conditions
    - (void)lock12 {
        __block pthread_mutex_t mutex;
        __block pthread_cond_t condition;
        pthread_mutex_init(&mutex, NULL);
        pthread_cond_init(&condition, NULL);
            pthread_mutex_lock(&mutex);
                sleep(1);
                    pthread_cond_signal(&condition);
            pthread_cond_wait(&condition, &mutex);
            pthread_mutex_unlock(&mutex);
