绑定端口并向Selector注册accept事件 4
look_w
2019-4-12 16:54
回过神来我们接着找unsalf的初始化实例。继续往上查看的构造方法,调用了抽象方法newUnsafe,NioServerSocketChannel继承了NioSocketChannle,最终发现unsafe其实是NioSocketChannelUnsafe
protected AbstractChannel(Channel parent) {
this.parent = parent;
id = newId();
unsafe = newUnsafe();
pipeline = newChannelPipeline();
@Override
protected AbstractNioUnsafe newUnsafe() {
return new NioSocketChannelUnsafe();
进入查看其bind(),该方法在其父类AbstractChannel.AbstractUnsafe#bind()中
@Override
public final void bind(final SocketAddress localAddress, final ChannelPromise promise) {
//省略代码
//未绑定之前:未激活状态
boolean wasActive = isActive();
try {
//进行绑定,成功后激活状态
doBind(localAddress);
} catch (Throwable t) {
safeSetFailure(promise, t);
closeIfClosed();
return;
//判断是哦付激活来进行 Event传播:ChannelActive
if (!wasActive && isActive()) {
invokeLater(new Runnable() {
@Override
public void run() {
pipeline.fireChannelActive();
safeSetSuccess(promise);
这里有两个地方指的继续深入查看其源码,一个是doBind()绑定端口,另一个是fireChannelActive()传播事件,我们当前的节点是在pipleline头部 HeadContext里面。
doBind()最终进入NioServerSocketChannel#doBind()调用了jdk底层的端口绑定方法。完成了绑定。
@Override
protected void doBind(SocketAddress localAddress) throws Exception {
if (PlatformDependent.javaVersion() >= 7) {
javaChannel().bind(localAddress, config.getBacklog());
} else {
javaChannel().socket().bind(localAddress, config.getBacklog());
进入DefaultChannelPipeline.HeadContext#channelActive()发现调用了readIfIsAutoRead()
@Override
public void channelActive(ChannelHandlerContext ctx) throws Exception {
ctx.fireChannelActive();
readIfIsAutoRead();
