标题: java下载html页面---把网页内容保存成本地html(2) [打印本页]
作者: look_w    时间: 2019-4-20 14:42     标题: java下载html页面---把网页内容保存成本地html(2)
java读写txt
把txt后缀改成html即可
    public static void writeToFile(String fileName, String content) {
            String time = DATE_FORMAT.format(Calendar.getInstance().getTime());
            File dirFile = null;
            try {
                dirFile = new File("e:\\" + time);
                if (!(dirFile.exists()) && !(dirFile.isDirectory())) {
                    boolean creadok = dirFile.mkdirs();
                    if (creadok) {
                        System.out.println(" ok:创建文件夹成功! ");
                    } else {
                        System.out.println(" err:创建文件夹失败! ");
            } catch (Exception e) {
                e.printStackTrace();
            String fullPath = dirFile + "/" + fileName + ".txt";
            write(fullPath, content);
         * 写文件
         * @param path
         * @param content
        public static boolean write(String path, String content) {
            String s = new String();
            String s1 = new String();
            BufferedWriter output = null;
            try {
                File f = new File(path);
                if (f.exists()) {
                } else {
                    System.out.println("文件不存在,正在创建...");
                    if (f.createNewFile()) {
                        System.out.println("文件创建成功!");
                    } else {
                        System.out.println("文件创建失败!");
                BufferedReader input = new BufferedReader(new FileReader(f));
                while ((s = input.readLine()) != null) {
                    s1 += s + "\n";
                System.out.println("原文件内容:" + s1);
                input.close();
                s1 += content;
                output = new BufferedWriter(new FileWriter(f));
                output.write(s1);
                output.flush();
                return true;
                return false;
            } finally {
                if (output != null) {
                    try {
                        output.close();
                    } catch (IOException e) {
