DSP design Engineer
Description:
The candidate will join a team of algorithm design and FPGA prototyping involved in the development of advanced digital signal processing algorithm for the physical layer of high speed wired data communication IC.
Responsibility:
l Design and develop PAM/QAM single/Multi-carrier transceivers, multi-input adaptive equalizers/echo cancellers, multi-dimentional trellis encoder/decoder, timing recovery, digital filters, interface with analog blocks and MAC/switch blocks.
l Create bit-exact Matlab/C system model and perform simulation.
l Design and simulate verilog RTL code using synopsys and cadence EDA tools.
l Prototype, debug and verify RTL code on Xilinx multi-FPGA platform.
l Perform coding, synthesis, timing closure, placement and route on FPGA.
Job Requirements:
l MSEE.or Ph.D. With 5+ years of experience in developing, implementing, and debugging high-performance communications and DSP ASIC products.
l Strong academic background of digital communication theory with proficient Matlab/C programming and simulation skills.
l Extensive verilog RTL experience including design, verification, synthesis, and debugging.
l Proficiency of Xilinx FPGA prototyping.
l Solid hands-on experience of using different lab equipment such as oscilloscopes, logic analyzer, signal generator, spectrum analyzer, etc.
l Fluency in English reading and writing.
l IEEE 802.3 or previous Ethernet product development experience is a plus.
