我装的是cadence15.7,破解之后allegro可以使用,而capture也可以打开,但是一打开图纸就出现附件中的窗口,请大家帮忙解决?
没有附件啊?是怎么回事,说清楚一点。。。。是说这个吗??
This application,OrCAD Capture,has encounterned following unrecoverable exception,and hence needs to be closed down
EXCEPTION_ACCESS_VIOLATION::
One of the theads has tried to read from or write to a virtual ddress for which it does not have the appropriate access
Do you wang to save all the open design now before Capture closes?
OrCAD 出错解决方法[转]
使用OrCAD 10.5会出现如下问题的说明:
exception access violation
threads has read from or write to a virtual address for which it does not have the appropriate access
当用ORCAD10.5打开一个文件时,弹出错误窗口,大意是一个线程读取虚拟地址错误,程序将关闭,点确定是保存后再关闭,点取消是直接关闭程序
解决方法:
HKEY_CURRENT_USER \Software\Microsoft\Windows\CurrentVersion\Policies\Explorer下的 NoRecentDocsHistory注册表项(DWORD类型的)设置为0,重启explorer.exe进程
