楼主最好把提示贴出来,便于分析是什么的问题。
不然可能性也太多了
我的是并口连接,我已经检查过电缆,也试过将并口设置为旧式即插即用型,也是出现下面这问题
Welcome to iMPACT! - The intelligent Multi-purpose Programming And Configuration Tool
AutoDetecting cable. Please wait.
CB_PROGRESS_START - Starting Operation.
Connecting to cable (USB Port).
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (COM1 Port).
Connecting to cable (COM2 Port).
Connecting to cable (COM3 Port).
Connecting to cable (COM4 Port).
Elapsed time = 25 sec.
Cable autodetection failed.
'1': Loading file 'xtest1.bit' ...
done.
还有这个ModelSim 6.0是怎么一回事,老是报错
Updating: Generate Expected Simulation Results
Starting: 'exewrap -tapkeep -mode pipe -sen 50 -tcl -command C:/Xilinx/data/projnav/__simulateAnnoTestBench.tcl __antTOano.rsp'
Creating TCL Process
Running Automatic Do File: counter_tbw.ado
Starting: '@HKLM/SOFTWARE/Classes/XLNXEDA/products/DESIGNCNTR10/paths/VSystemPath/@/vsim -c -do counter_tbw.ado'
fatal error(0002): The system cannot find the file specified.
Tcl Unable to run the process due to a system error.
VSim failed to simulate annotated testbench
Reason:
Done: failed with exit code: 0002.
连接的问题和例子没有任何关系,这是一个硬件问题,只和下载电缆及其设置有关系,另外检查一下你板子上送给下载线的电源是否正确。
那么仿真是怎么一回事,老报错
在xilinx专区有一个置顶的帖子,是关于modelsim的,你可以看看。
