verilog///////////////////////////////////////////////
// RS232异步数据接收模块 baudClk8x/8,8,n,1
// 2002-2005
module UartRec(
rst, //异步复位
rxd, //串行数据
baudClk8x, //8X波特率时钟
irq, //中断请求
dataOut //数据输出
input rst,rxd,baudClk8x;
output irq;
output[7:0] dataOut;
parameter idle_state=0 , verifyStartBit_state=1,
startBitOk_state=2, bit0_state=3,
bit1_state=4 , bit2_state=5,
bit3_state=6 , bit4_state=7,
bit5_state=8 , bit6_state=9,
bit7_state=10 ;
reg [3:0] bitState; //接收状态机
reg [7:0] shifter; //移位寄存器
reg [7:0] dataOut; //输出锁存器
reg [2:0] bitCounter; //采样计数器
reg irq;
always @(posedge rst or posedge baudClk8x)
begin
if(rst)
begin
bitState<=4'd0;//idle_state;
bitCounter<=3'd0;
shifter<=8'd0;
end
else
begin
if(bitState==4'd0)//idle_state
begin
if(!rxd)
begin
bitState<=bitState+1;
bitCounter<=3'd0;
end
end
else if(bitState==4'd1)//verifyStartBit_state:
begin
if(bitCounter==3'd3)
begin
if(!rxd) //校验起始位是否依然有效
bitState<=bitState+1;//4'd2 bit 0 state
else
bitState<=4'd0; //idle_state;
bitCounter<=3'd0;
end
else
bitCounter<=bitCounter+1;
end
else if(bitState==4'd10)//bit7_state
begin
if(bitCounter==3'd7) //返回初始状态,不检查停止位
begin
bitCounter<=3'd0;
bitState<=4'd0;
end
else
end
else //bitState=2~9 8个数据位接收
begin
begin
shifter<={rxd,shifter[7:1]};
bitCounter<=3'd0;
end
else
end
end
end
always @(posedge rst or negedge baudClk8x)
begin
if(rst)
begin
dataOut<=0;
irq<=0;
end
begin
dataOut<=shifter;
irq<=1;
end
else
irq<=0;
end
endmodule
浏览了一番!
