NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
ROM = READ_ONLY 0xDC00 TO 0xFBFF;
Z_RAM = READ_WRITE 0x0060 TO 0x0090;
RAM = READ_WRITE 0x00a0 TO 0x015F;
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
DEFAULT_RAM INTO RAM;
DEFAULT_ROM, ROM_VAR, STRINGS INTO ROM; /* In case you want to use as well, be sure the option -OnB=b is passed to the compiler. */
_DATA_ZEROPAGE, MY_ZEROPAGE INTO Z_RAM;
END
STACKSIZE 0x30
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
VECTOR 2 IRQ1_ISR
VECTOR 6 Timer_ISR
