if (NVICSTRM != 0xFF) {
ICSTRM = NVICSTRM; // load trim value if location not blank
ICSC1 = C1;
ICSC2 = C2;
while (ICSC1_CLKS != ICSSC_CLKST) {} // wait for clk state to match clk select
FCDIV = 39;
} //end ics_setup
/* Uncomment this function call after using Device Initialization
to use the generated code */
/* MCU_init(); */
InitPorts(); //初始化端口
InitSysOpts(); //初始化系统寄存器
InitRTI_512ms();
//ics_intclk(0x04,0x08); //set ICS for FEI mode,Fbus=8M
InitADC_SAMPLE();
