标题: debug error,pls give some advice.thanks [打印本页] 作者: david007 时间: 2008-3-24 17:54 标题: debug error,pls give some advice.thanks
Link Error : L1822: Symbol SetRectOnOff in file C:\wrk\Gaia\Gaia_incl_UML\_C32_L45J\GAIA_C32_UML_Data\Banked_Flash\ObjectCode\RS232TasksEvery10Millis.c.o
is undefined 作者: strongchen 时间: 2008-3-25 10:28
There is a not defined symbol on your file. Please just find and check this symbol.作者: david007 时间: 2008-3-25 11:16
I solve this problem.It is caused by PC system language setting. 作者: david007 时间: 2008-3-25 11:20
Another question pls.When I open a .mcp project,there are so many remarks as below:
Duplicate file "SecondaryDefConfig.c" removed from group "codeesignefaults".
Why?作者: strongchen 时间: 2008-3-25 14:33
It's weird. Could you upload your project?作者: david007 时间: 2008-3-26 13:52
Sorry,this project is a company confidential file.Ican only introduce to you some aspects.For example,it is for UML project and there are so many folders in this project and there are so many .h files.
When I open this project,there will be a "Rescue folder" like below: 作者: david007 时间: 2008-3-26 13:53
