标题: AC16芯片怎么了 [打印本页]
作者: waszhang    时间: 2008-7-18 11:31     标题: AC16芯片怎么了
不知是什么原因,各位大虾给解释一下了。在线等候!
[此贴子已经被作者于2008-7-18 11:32:59编辑过]
图片附件: [AC16芯片怎么了] ygtrYWYX.jpg (2008-7-18 11:15, 119.05 KB) / 下载次数 169
http://bbs.eccn.com/attachment.php?aid=4732&k=312cc7f945e559d25825641cf3d63fc3&t=1732521288&sid=461q26
作者: waszhang    时间: 2008-7-18 11:45
是不是芯片又挂了,前几天遇到了
坊真器调试HCS08核的LC 60时,样片中一片突然出现以下界
命令窗口显示
DiGdiGetFeatures()==> Features Already Loaded
Writing To Memory Address: 0x019DC, count: 1
82
DiMemoryWrite()==> DI_OK
Reading From Memory Address: 0x019DC, count: 1
DiMemoryRead()==> DI_OK
00
Trying to set Software Breakpoint at 0x019DC
==> DI_OK
Returned Breakpoint id: 0
Writing To Memory Address: 0x01816, count: 1
80
Writing To Memory Address: 0x01810, count: 4
00 00 00 00
Writing To Memory Address: 0x01817, count: 1
80
C0
Reading From Memory Address: 0x01810, count: 4
00 00 00 00
Reading From Memory Address: 0x01816, count: 2
40 80
DiExecSingleStep(1)==> DI_OK
GDI DLL called: DI_CB_MTWKS_EXTENSION_Callback(MTWKS_CB_DISPLAYLINE)
Target Speed Change Detected - New Speed 8.30 MHz
Reading Register PC (id:0):
DiRegisterRead()==> DI_OK
PC (id:0) -> 0x0FFFF
80
00 00 00 00
80
C0
00 00 00 00
40 80
Clearing Breakpoint id: 0
DiBreakpointClear(0)==> DI_OK
STARTED
RUNNING
ILLEGAL_BP
Reading Register SP (id:1):
SP (id:1) -> 0x0FFFF
Reading Register A (id:2):
A (id:2) -> 0x0FF
Reading Register H (id:4):
H (id:4) -> 0x0FF
Reading Register X (id:3):
X (id:3) -> 0x0FF
Reading Register CCR (id:5):
CCR (id:5) -> 0x0FF
Reading From Memory Address: 0x00, count: 384
F0 00 00 00 38 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00
00 04 00 00 C0 00 00 00 04 00 00 20 00 00 00 00 04 00 00 20 00 00 00 00 44 00 00 01 00 C0 80 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
点运行.或其他命令时,命令行重复出现上面的内容,无法正常运行.麻烦你帮忙看看,是不是LC60FLASH檫写损坏,我这边只是调试,也檫除不了多少次,还是芯片不稳定等其他问题.
[此贴子已经被作者于2008-7-18 11:46:16编辑过]
作者: strongchen    时间: 2008-7-18 16:10
如果其他的芯片都是好的,就这一片不行,而且电路也没有问题的话,那应该是芯片坏掉了。
作者: waszhang    时间: 2008-7-18 18:20
哦,我现在用到两个芯片9S08AC16 和9S08LC60,已经从代理商那得到回复9S08LC60是坏了,AC16电脑重起后断开所有连接,重新连接下载又好了,幸运呀!但到底是什么问题呀!
难道是用的飞锐泰克的HCS08仿真器不稳定,造成的.那为什么这么容易坏呢?
作者: strongchen    时间: 2008-7-21 11:05
如果没有正负过电压,芯片一般也不会坏的。
作者: waszhang    时间: 2008-8-6 11:26
哦,谢谢!现在功耗做不下来呀!好象进不了STOP2和STOP3,谁有事例程序,给我发一封,waszhang@sohu.com
