大家好我用99SE,DRC时结果是如下文/请教高手们这是什么问题.Protel Design System Design Rule Check
PCB File : PCB3.PCB
Date : 27-Sep-2008
Time : 12:21:38
Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board )
Violation between Pad U1-10(9960mil,5080mil) MultiLayer and
Track (9740mil,5300mil)(9940mil,5100mil) TopLayer
Track (9940mil,5100mil)(9960mil,5100mil) TopLayer
Violation between Pad C3-2(10480mil,5600mil) MultiLayer and
Track (10500mil,5620mil)(10600mil,5620mil) TopLayer
Violation between Pad R9-2(9060mil,4540mil) MultiLayer and
Track (9060mil,4520mil)(9120mil,4460mil) TopLayer
Violation between Track (9100mil,5040mil)(9100mil,5120mil) BottomLayer and
Track (9060mil,5160mil)(9100mil,5120mil) BottomLayer
Violation between Track (9800mil,5300mil)(9800mil,5460mil) BottomLayer and
Track (9800mil,5460mil)(9920mil,5580mil) BottomLayer
Violation between Pad R10-1(9180mil,4960mil) MultiLayer and
Track (9100mil,5040mil)(9180mil,4960mil) BottomLayer
Violation between Pad D8-A(9420mil,4580mil) MultiLayer and
Track (9420mil,4580mil)(9420mil,4820mil) BottomLayer
Violation between Pad C4-1(9740mil,5760mil) MultiLayer and
Track (9740mil,5500mil)(9740mil,5760mil) BottomLayer
Rule Violations :9
Processing Rule : Broken-Net Constraint ( (On the board ) )
Violation Net +5 is broken into 2 sub-nets. Routed To 92.86%
Subnet : U1-20 JP1-3 R1-2 C4-2 C5-1 R3-2 R4-2 R2-2 C3-1 R8-2
R7-2 R6-2 R5-2 S1-2
Subnet : R10-1
Violation Net GND is broken into 3 sub-nets. Routed To 66.67%
Subnet : R9-2
Subnet : JP1-4 C2-1 C1-2 C4-1 C3-2
Subnet : U1-10
Violation Net NetR1_1 is broken into 2 sub-nets. Routed To 0.00%
Subnet : D8-A
Subnet : R1-1
Rule Violations :3
Processing Rule : Clearance Constraint (Gap=10mil) (On the board ),(On the board )
Violation between Track (10500mil,5620mil)(10600mil,5620mil) TopLayer and
Track (10260mil,5820mil)(10480mil,5600mil) TopLayer
Violation between Pad U1-1(9060mil,5080mil) MultiLayer and
Violation between Pad U1-13(9760mil,5380mil) MultiLayer and
Violation between Pad U1-5(9460mil,5080mil) MultiLayer and
Track (9500mil,5060mil)(9500mil,5200mil) BottomLayer
Track (9480mil,5040mil)(9500mil,5060mil) BottomLayer
Track (9480mil,4880mil)(9480mil,5040mil) BottomLayer
Track (9720mil,5340mil)(9720mil,5480mil) BottomLayer
Rule Violations :16
Processing Rule : Width Constraint (Min=10mil) (Max=10mil) (Prefered=10mil) (On the board )
Violation Track (9140mil,5460mil)(9240mil,5460mil) TopLayer Actual Width = 20mil
Violation Track (9660mil,5580mil)(9840mil,5760mil) TopLayer Actual Width = 20mil
Violation Track (10160mil,5780mil)(10220mil,5720mil) TopLayer Actual Width = 20mil
Violation Track (9960mil,5780mil)(10160mil,5780mil) TopLayer Actual Width = 20mil
Violation Track (9940mil,5760mil)(9960mil,5780mil) TopLayer Actual Width = 20mil
Violation Track (9840mil,5760mil)(9940mil,5760mil) TopLayer Actual Width = 20mil
Violation Track (10400mil,5000mil)(10540mil,5000mil) TopLayer Actual Width = 20mil
Violation Track (10540mil,5000mil)(10540mil,5020mil) TopLayer Actual Width = 20mil
Violation Track (10780mil,5020mil)(10800mil,5000mil) TopLayer Actual Width = 20mil
Violation Track (10660mil,5480mil)(10780mil,5600mil) TopLayer Actual Width = 20mil
Violation Track (9200mil,5820mil)(9400mil,5820mil) TopLayer Actual Width = 20mil
Violation Track (9400mil,5820mil)(9460mil,5760mil) TopLayer Actual Width = 20mil
Violation Track (9460mil,5760mil)(9740mil,5760mil) TopLayer Actual Width = 20mil
Violation Track (10260mil,5820mil)(10480mil,5600mil) TopLayer Actual Width = 20mil
Violation Track (9800mil,5820mil)(10260mil,5820mil) TopLayer Actual Width = 20mil
Violation Track (9740mil,5760mil)(9800mil,5820mil) TopLayer Actual Width = 20mil
Violation Track (9240mil,5460mil)(9300mil,5520mil) TopLayer Actual Width = 20mil
Violation Track (9360mil,5580mil)(9520mil,5580mil) TopLayer Actual Width = 20mil
Violation Track (9520mil,5580mil)(9660mil,5580mil) TopLayer Actual Width = 20mil
Violation Track (10100mil,5480mil)(10240mil,5480mil) TopLayer Actual Width = 20mil
Violation Track (10240mil,5480mil)(10360mil,5480mil) TopLayer Actual Width = 20mil
Violation Track (10360mil,5480mil)(10660mil,5480mil) TopLayer Actual Width = 20mil
Violation Track (10540mil,5020mil)(10680mil,5020mil) TopLayer Actual Width = 20mil
Violation Track (10680mil,5020mil)(10780mil,5020mil) TopLayer Actual Width = 20mil
Violation Track (9300mil,5520mil)(9360mil,5580mil) TopLayer Actual Width = 20mil
Violation Track (9720mil,5300mil)(9740mil,5300mil) TopLayer Actual Width = 20mil
Violation Track (9740mil,5300mil)(9940mil,5100mil) TopLayer Actual Width = 20mil
Violation Track (9940mil,5100mil)(9960mil,5100mil) TopLayer Actual Width = 20mil
Violation Track (9060mil,5380mil)(9140mil,5460mil) TopLayer Actual Width = 20mil
Violation Track (10500mil,5620mil)(10600mil,5620mil) TopLayer Actual Width = 20mil
Violation Track (10600mil,5620mil)(10680mil,5700mil) TopLayer Actual Width = 20mil
Violation Track (10680mil,5700mil)(10840mil,5700mil) TopLayer Actual Width = 20mil
Violation Track (10840mil,5700mil)(10900mil,5640mil) TopLayer Actual Width = 20mil
Violation Track (10880mil,4540mil)(10900mil,4560mil) TopLayer Actual Width = 20mil
Violation Track (10800mil,4540mil)(10880mil,4540mil) TopLayer Actual Width = 20mil
Violation Track (10740mil,4480mil)(10800mil,4540mil) TopLayer Actual Width = 20mil
Violation Track (9540mil,4480mil)(10740mil,4480mil) TopLayer Actual Width = 20mil
Violation Track (9520mil,4460mil)(9540mil,4480mil) TopLayer Actual Width = 20mil
Violation Track (9120mil,4460mil)(9520mil,4460mil) TopLayer Actual Width = 20mil
Violation Track (9060mil,4520mil)(9120mil,4460mil) TopLayer Actual Width = 20mil
Violation Track (10900mil,4560mil)(10900mil,5640mil) TopLayer Actual Width = 20mil
Violation Track (10220mil,5720mil)(10240mil,5700mil) BottomLayer Actual Width = 20mil
Violation Track (10240mil,5480mil)(10240mil,5700mil) BottomLayer Actual Width = 20mil
Violation Track (10400mil,5000mil)(10420mil,5020mil) BottomLayer Actual Width = 20mil
Violation Track (10420mil,5020mil)(10420mil,5420mil) BottomLayer Actual Width = 20mil
Violation Track (10360mil,5480mil)(10420mil,5420mil) BottomLayer Actual Width = 20mil
Violation Track (10620mil,5180mil)(10680mil,5120mil) BottomLayer Actual Width = 20mil
Violation Track (10680mil,5020mil)(10680mil,5120mil) BottomLayer Actual Width = 20mil
Violation Track (9060mil,5160mil)(9100mil,5120mil) BottomLayer Actual Width = 20mil
Violation Track (9060mil,5160mil)(9060mil,5380mil) BottomLayer Actual Width = 20mil
Violation Track (9100mil,5040mil)(9100mil,5120mil) BottomLayer Actual Width = 20mil
Violation Track (9100mil,5040mil)(9180mil,4960mil) BottomLayer Actual Width = 20mil
Violation Track (9800mil,5300mil)(9800mil,5460mil) BottomLayer Actual Width = 20mil
Violation Track (9760mil,5260mil)(9800mil,5300mil) BottomLayer Actual Width = 20mil
Violation Track (9540mil,5260mil)(9760mil,5260mil) BottomLayer Actual Width = 20mil
Violation Track (9500mil,5220mil)(9540mil,5260mil) BottomLayer Actual Width = 20mil
Violation Track (9500mil,5200mil)(9500mil,5220mil) BottomLayer Actual Width = 20mil
Violation Track (9500mil,5060mil)(9500mil,5200mil) BottomLayer Actual Width = 20mil
Violation Track (9480mil,5040mil)(9500mil,5060mil) BottomLayer Actual Width = 20mil
Violation Track (9480mil,4880mil)(9480mil,5040mil) BottomLayer Actual Width = 20mil
Violation Track (9420mil,4820mil)(9480mil,4880mil) BottomLayer Actual Width = 20mil
Violation Track (9420mil,4580mil)(9420mil,4820mil) BottomLayer Actual Width = 20mil
Violation Track (9740mil,5500mil)(9740mil,5760mil) BottomLayer Actual Width = 20mil
Violation Track (9720mil,5480mil)(9740mil,5500mil) BottomLayer Actual Width = 20mil
Violation Track (9720mil,5340mil)(9720mil,5480mil) BottomLayer Actual Width = 20mil
Violation Track (9720mil,5300mil)(9720mil,5340mil) BottomLayer Actual Width = 20mil
Violation Track (9400mil,5520mil)(9400mil,5820mil) BottomLayer Actual Width = 20mil
Rule Violations :67
Processing Rule : Hole Size Constraint (Min=1mil) (Max=100mil) (On the board )
Rule Violations :0
Violations Detected : 95
Time Elapsed : 00:00:00
[此贴子已经被作者于2008-9-30 19:51:18编辑过]
第一:绝缘间距不符合
第二:有些网络未布通,如+5v,netr1-1
第三:短路
第四:线宽不符合
