nand flash的时序一般都是一样的,都有可能,楼主可以试试下面的测试程序,在offset 2的地方测一下,flash可能是内部颗粒出问题,这是常有的事,再分析一下。
#include <stdio.h>
#include <sys/alt_flash.h>
#include "system.h"
#include <unistd.h>
#define DATA_OFFSET 0x300000
int main(void)
alt_flash_fd* flash_handle;
FILE *uart;
char write_data = 0;
char read_data = 0;
write_data = 100;
uart = fopen(UART_NAME,"w");
flash_handle = alt_flash_open_dev(CFI_FLASH_NAME);
fprintf(uart, "open flash device...\n");
usleep(10000);
if (flash_handle)
fprintf(uart, "open flash device successed!!!\n");
usleep(10000);
alt_write_flash(flash_handle, DATA_OFFSET, &write_data, 1);
fprintf(uart, "wirte_data = %d\n", write_data);
usleep(10000);
alt_read_flash(flash_handle, DATA_OFFSET, &read_data, 1);
fprintf(uart, "read_data = %d\n", read_data);
usleep(10000);
if(read_data == write_data)
fprintf(uart, "flash write and read successed!!!\n");
usleep(10000);
else
fprintf(uart, "flash write or read failed!!!\n");
usleep(10000);
alt_flash_close_dev(flash_handle);
fprintf(uart, "close flash device...\n");
usleep(10000);
else
fprintf(uart, "open flash device failed!!!\n");
usleep(10000);
[此贴子已经被作者于2008-9-21 8:36:34编辑过]
