To suzhou huqiuwedding gown for the selection of a body MM gauzeThe wedding day by day, whether you are not perfect figure to feel panicked? Choose gauze is crucial in. Will It! Suzhou huqiu every wedding gown street can bring a surprise to you, let you shape looks.
The bottom line is painted large and leg buttock (too thick, etc...).
Try to loose skirt design mainly come cloak, don't pick a skirt design line of the merlion styles.
The lower abdomen, waist u
Can choose waist line design with triangular, or the marriage gauze of tall waist doll outfit design of marriage gauze, can shift the focus of fuzzy visual.
The arm painted the
Can choose to adorn with complete amice design in cool autumn arm, covering season nor show abrupt, try not to choose too fine aglet of marriage gauze, lest contrast more highlights faults.
U shape too thin person
The best way to avoid choose too high or low bosom of bare design, lest bear, can choose the high-necked long or take the marriage gauze of Victoria style, can show temperament and presence.
Painted body too plump
Elegant and low-key with simple design, clipping is too heavy and complicated, but will have the design HuBeiXiongYao illusion, in case the skirt is tight, but will emphasize the design of discordant. Now
The skin white painted
Is not the problem, in dress collocation of color will not too big, more convenient.
U is dark skin
Can choose a few bright lubricious department, to create the dress sexy breath. Contrast health, But such is the premise of trying, healthy and have sense of shiny with swarthy, healthy skin gloss effect, to perfect his charming qualities. Foil
U color of skin dark yellow
Don't try to similar purple, sapphire blue, cinnamon, lotus, copper aureate... This type of dress can make color of skin is not fair show dark yellow, originally a sallow skin and dress is the illusion of fusion, completely unable to appear. wedding gown,Wedding dresses作者: asdfgcjw 时间: 2011-4-15 12:57
