seuafu2005 你好,麻烦进来看看[求助]
看您前面的帖子说到:
据我所知freescale有一个manyhops的demo,实现mesh的功能
能够告诉我如何得到这个demo么。我想看看
告诉我你的EMAIL地址,我可以把这个DEMO发到你信箱里面。这个程序是在z-stack上写的。
jimmytan 您好 我的地址tianandy_tom@yahoo.com.cn
万分感谢
jimmytan: 可以发给我一份吗?
在网站只有星型的例子.
freescle的东西是不错的,只是开发工具有点小贵
你说的星型是802.15.4 EVK 1.063里面那个MyStarNetworkApp.mpc么
星型网络可以参考802.15.4 EVK 1.063里面那个MyStarNetworkApp.mpc。
jimmytan 您好 关于星型网的一些问题我发送到你邮箱了,希望您能看看,在这里再贴一下,下面是星型网协调器程序中发送数据的函数
void App_TransmitData(void)
uint8_t msduLength = 0;
uint8_t morePackets = 1;
uint8_t deviceAddress = 0x01;
uint8_t ret;
static uint8_t dataBuffer[DEFAULT_DATA_LENGTH]; /* Prevent slow allocation on stack */
/* We transmit only if at least one device is associated. */
if(addressesMap == 0)
return;
/* Send packets only if we can send info to all End Devices */
if(numPendingPackets > 0)
if(packetDropped > 0)
Uart_Print("Packet dropped.\n");
packetDropped = 0;
return;
/* Get data to be transmitted from one source */
/* Try first the LED counter */
if(counterLEDsModified)
counterLEDsModified = FALSE;
packetDropped = FALSE;
dataBuffer[0] = counterLEDs & 0x0F;
msduLength = 1;
else
/* Else try to get data from the UART. */
msduLength = Uart_PollMessage(dataBuffer);
/* For every device associated, if there is still room in the queue
allocate and send a packet */
if(msduLength != 0)
/* Find the first associated end device. We have at least one.*/
while((deviceAddress & addressesMap) == 0)
deviceAddress = deviceAddress << 1;
/* Transmit packets to the devices */
do
morePackets = 0;
if (numPendingPackets < MAX_PENDING_DATA_PACKETS && NULL == pPacket)
pPacket = MSG_Alloc(sizeof(nwkToMcpsMessage_t) - 1 + DEFAULT_DATA_LENGTH);
if (pPacket != NULL)
/* Create an MCPS-Data Request message containing the data. */
pPacket->msgType = gMcpsDataReq_c;
/* Copy data to be sent to packet */
memcpy(pPacket->msgData.dataReq.msdu, (void *)dataBuffer, msduLength);
/* Create the header using device information stored when creating
the association response. In this simple example the use of short
addresses is hardcoded. In a real world application we must be
flexible, and use the address mode required by the given situation. */
pPacket->msgData.dataReq.dstAddr[0] = deviceAddress;
pPacket->msgData.dataReq.dstAddr[1] = 0;
memcpy(pPacket->msgData.dataReq.srcAddr, (void *)shortAddress, 2);
memcpy(pPacket->msgData.dataReq.dstPanId, (void *)panId, 2);
memcpy(pPacket->msgData.dataReq.srcPanId, (void *)panId, 2);
pPacket->msgData.dataReq.dstAddrMode = gAddrModeShort_c;
pPacket->msgData.dataReq.srcAddrMode = gAddrModeShort_c;
pPacket->msgData.dataReq.msduLength = msduLength;
/* Request MAC level acknowledgement, and
indirect transmission of the data packet */
pPacket->msgData.dataReq.txOptions = gTxOptsAck_c | gTxOptsIndirect_c;
/* Give the data packet a handle. The handle is
returned in the MCPS-Data Confirm message. */
pPacket->msgData.dataReq.msduHandle = msduHandle++;
/* Add the packet to tracking list in the purger module. */
ret = Purger_Track(pPacket->msgData.dataReq.msduHandle, 0, deviceAddress, counterLEDs);
/* Send the Data Request to the MCPS */
NR MSG_Send(NWK_MCPS, pPacket);
/* Prepare for another data buffer */
pPacket = NULL;
numPendingPackets++;
/* Move to next associated device */
do
while(((deviceAddress & addressesMap) == 0) && (deviceAddress < 0x10));
/* Continue if we haven't passed the last possible device address. */
morePackets = deviceAddress < 0x10;
else
Uart_Print("Packet NULL.\n");
while (morePackets);
就是星型网络中协调器发送数据的函数,从代码看是支持四个END Device,其地址为01,02,04,08。协调器往end device中发送数据,但是当连接上第4个时候,向第4个end device发送数据时候会出现 Packet NULL。前面3个都能正常发送数据的
help!!!
看你的描述,第4个DEVICE已经连接上了网络,但是coordinator不能正常给这个device发送数据。在MyStarNetworkApp.mpc中,在MAC层是定义了可以连接4个END DEVICE.你用的是MyStarNetworkApp.mpc这个程序吗?首先,你要确认第四个device是否已经加入网络。从发射方式看,是indirect方式,所以应该是end device主动去polling.Coordinator会把数据存在自己的buffer里面,然后等着end device来取。我想可能是因为第四个device的polling的时间太长,数据在coordinator中丢掉了。你可以试试把polling的间隔缩短一点。
首先感谢jimmytan的帮助,我用的是MyStarNetworkApp.mpc这个程序,确认第四个是连上网络了。但是四个 device的程序中除了预定义的数据,其他都是一摸一样的,为什么前3个不会polling时间长,而最后一个出现polling时间过长呢?
[此贴子已经被作者于2006-10-10 11:20:47编辑过]
很难知道你的问题在哪里。你用的是beacon mode还是 non-beacon mode? 如果你用的是beacon mode,在coordinator的beacon信息里面,应该包含具体device的地址。如果你是
packet null的话,那就表明在coordinator根本就没有pending data.
jimmytan不知道您现在有没有那个Mystarnetworkapp.mpc的代码?可以看一下么.一部分函数确实也不能看出什么
我现在手头没有,你是在飞思卡尔网站上下的不? 可以给我一个链接不?谢谢。
我发送给您吧 呵呵
jimmytan你好 demo程序已经发送过来 是5个分割文件 请查看
