STM32-移植FATFS的NANDFLASH驱动(3)
2,然后对媒介格式化,创建读写文件:
[cpp] view plaincopy
  • void test_fatfs(void)
  •       FATFS fs;
  •    FIL fl;
  •    FATFS *pfs;
  •    DWORD clust;
  •    unsigned int r,w,i;
  •    FRESULT  res;
  •   // NF_CHKDSK(0,1024);
  •    display_page(0,0);
  •   // for mount
  •    res=f_mount(0,&fs);
  •    printf("f_mount=%x \n\r",res);
  •   // for format
  •    //res=f_mkfs(0,1,2048);  //MUST Format for New NANDFLASH !!!
  •    //printf("f_mkfs=%x \n\r",res);
  •   // for
  •    pfs=&fs;
  •    res = f_getfree("/", &clust, &pfs);
  •    printf("f_getfree=%x \n\r",res);
  •    printf("\n\r%lu MB total drive space."
  •        "\n\r%lu MB available.\n\r",
  •      (DWORD)(pfs->max_clust - 2) * pfs->csize /2/1024,
  •      clust * pfs->csize /2/1024);
  •   // for read
  •       res=f_open(&fl,"/test2.dat",FA_OPEN_EXISTING | FA_READ);
  •       printf("f_open=%x \n\r",res);
  •    for(i=0;i<2;i++)
  •     for(r = 0; r < NAND_PAGE_SIZE; r++)
  •      RxBuffer[r]= 0xff;
  •     res=f_read(&fl,RxBuffer,NAND_PAGE_SIZE,&r);
  •     printf("f_read=%x \n\r",res);
  •     if(res || r == 0)break;
  •            printf("D[%08x]=%02x ",(i*NAND_PAGE_SIZE+r),RxBuffer[r]);
  •            if((r%8)==7)
  •            {printf("\n\r");}
  •    f_close(&fl);
  •   // for write
  •    res=f_open(&fl,"/test2.dat",FA_CREATE_ALWAYS | FA_WRITE);
  •    for(i=0;i<2;i++)
  •     for(w = 0; w < NAND_PAGE_SIZE; w++)
  •      TxBuffer[w]=((w<<0)&0xff);
  •           res=f_write(&fl,TxBuffer,NAND_PAGE_SIZE,&w);
  •           printf("f_write=%x \n\r",res);
  •     if(res || w
  •    f_close(&fl);
  •   // for umount
  •    f_mount(0,NULL);
六,编写NANDFLASH接口
1,fsmc_nand.c文件:
  • /* Includes ------------------------------------------------------------------*/
  • #include "fsmc_nand.h"
  • #include "stm32f10x_conf.h"
  • /** @addtogroup StdPeriph_Examples
  • /** @addtogroup FSMC_NAND
  • /* Private typedef -----------------------------------------------------------*/
  • /* Private define ------------------------------------------------------------*/
  • #define FSMC_Bank_NAND     FSMC_Bank2_NAND
  • #define Bank_NAND_ADDR     Bank2_NAND_ADDR
  • #define Bank2_NAND_ADDR    ((uint32_t)0x70000000)
  • /* Private macro -------------------------------------------------------------*/
  • /* Private variables ---------------------------------------------------------*/
  • /* Private function prototypes -----------------------------------------------*/
  • /* Private functions ---------------------------------------------------------*/
  •    * @brief  Configures the FSMC and GPIOs to interface with the NAND memory.
  •    *   This function must be called before any write/read operation
  •    *   on the NAND.
  •    * @param  None
  •    * @retval : None
  • void FSMC_NAND_Init(void)
  •    GPIO_InitTypeDef GPIO_InitStructure;
  •    FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
  •    FSMC_NAND_PCCARDTimingInitTypeDef  p;
  •    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
  •                           RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
  • /*-- GPIO Configuration ------------------------------------------------------*/
  • /* CLE, ALE, D0->D3, NOE, NWE and NCE2  NAND pin configuration  */
  •    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_14 | GPIO_Pin_15 |
  •                                   GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
  •                                   GPIO_Pin_7;
  •    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  •    GPIO_Init(GPIOD, &GPIO_InitStructure);
  • /* D4->D7 NAND pin configuration  */
  •    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  •    GPIO_Init(GPIOE, &GPIO_InitStructure);
  • /* NWAIT NAND pin configuration */
  •    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  •    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  • /* INT2 NAND pin configuration */
  •    GPIO_Init(GPIOG, &GPIO_InitStructure);
  •    /*-- FSMC Configuration ------------------------------------------------------*/
  •    p.FSMC_SetupTime = 0x1;
  •    p.FSMC_WaitSetupTime = 0x3;
  •    p.FSMC_HoldSetupTime = 0x2;
  •    p.FSMC_HiZSetupTime = 0x1;
  •    FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND;
  •    FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable;
  •    FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
  •    FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;
  •    FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_512Bytes;
  •    FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
  •    FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
  •    FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
  •    FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
  •    FSMC_NANDInit(&FSMC_NANDInitStructure);
  •    /* FSMC NAND Bank Cmd Test */
  •    FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
继承事业,薪火相传
