opencv开源图像处理函数库在S3C2440移植(2)
step1: 编译zlib
#tar xzf zlib-1.2.4.tar.gz
#cd zlib-1.2.4
./configure --prefix=$OPENCV_BUILD_DIR/install
#vi Makefile
替换gcc为arm-linux-gcc
替换ar为arm-linux-ar
替换ranlib为arm-linux-ranlib
#make
#make install
step2:编译jpeg库
#tar xzf jpegsrc.v8a.tar.gz
#cd jpeg-8a
./configure --host=arm-linux --prefix=$OPENCV_BUILD_DIR/install
#make
#make install
step3:编译libpng库
#tar xzf libpng-1.2.43.tar.gz
#cd libpng-1.2.43
#make
#make install
step4:编译OpenCV
#tar xjf OpenCV-2.0.0.tar.bz2
#cd OpenCV-2.0.0
#./configure --host=arm-linux --without-gtk --without-carbon  --without-quicktime --without-1394libs --without-ffmpeg --without-python --without-swig --disable-static --enable-shared --disable-apps CXX=arm-linux-g++  --prefix=$OPENCV_BUILD_DIR/install --libdir=$OPENCV_BUILD_DIR/install/lib -includedir=$OPENCV_BUILD_DIR/install/include
#make
#make install
最后,strip生成的库:
#find | xargs file | grep "not stripped" | cut -d: -f1 | xargs arm-linux-strip
3、编译程序编译基于openCV库的应用程序一般使用以下Makefile配合编译:注意LIBOPENCV变量的取值跟上面的一致
[plain] view plaincopy
  • TARGET = cvRect
  • SRC = cvRect.cpp
  • LIBOPENCV := /home/openCV/install
  • CFLAGS = -I$(LIBOPENCV)/include/opencv
  • LDFLAGS = -L$(LIBOPENCV)/lib -lm -lcv -lcvaux -lcxcore -lhighgui -lml -lpthread -ljpeg -lpng -lrt -lcxcore -lz
  • $(TARGET): $(SRC)
  •     arm-linux-g++ $(CFLAGS) $(SRC) -o $(TARGET) $(LDFLAGS)
  •     arm-linux-strip $(TARGET)
  • clean:
  •     rm -rf $(TARGET)
继承事业,薪火相传
