OpenResty(Lua)笔记总结(3)
lua获取GET 和 POST参数
    function getpost()
             local args = {}
             local request_method = ngx.var.request_method
             if  "GET" == request_method then
                         args  =  ngx.req.get_uri_args()
              elseif  "POST" == ngx.req.get_method() then
                         ngx.req.read_body()
                         args  =  ngx.req.get_post_args()
               end
               return args
    end
lua获取请求 body-适合获取http请求post和get参数【推荐】
ngx.req.get_body_data() 读请求体,会偶尔出现读取不到直接返回 nil 的情况。
所以得事先调用ngx.req.read_body(),强制本模块读取请求体
ngx.req.read_body()
local json_str = ngx.req.get_body_data()
--如果是json,则可以转化为table等等。。。
lua发起http get和post请求
    function http_post(url,table_par)
              local http = require "http"
              local httpc = http.new()
              local res, err = httpc:request_uri(url,{
                            method = 'POST',
                            body = cjson.encode(table_par),
                            headers = {["Content-Type"] = "application/x-www-form-urlencoded",}
                if not res then
                            return 100
                 end
                 return res.body
    end
    function comm_fun:http_get(url,table_par)
                 local httpc = http:new()
                 local res, err = httpc:request_uri(url, {
                              method = "GET",
                              query  = table_par,
                              --ssl_verify = false, -- 需要关闭这项才能发起https请求
                               headers = {["Content-Type"] = "application/x-www-form-urlencoded" },
                  if not res then
                               return 100
                   end
                   return res.body
        end
