UBUNTU 环境LNMP搭建
UBUNTU 环境LNMP搭建
ububtu16.04
      1. 换源(清华大学源/阿里)
       2。备份原文件 cd/etc/apt/
        然后会显示下面的源文件sources.list
    输入命令
    sudo cp sources.list sources.list.bak
    就是将sources.list备份到sources.list.bak
    sudo gedit sources.list打开文件,替换成清华源文件即可
清华大学源
# deb cdrom:[Ubuntu 16.04 LTS _Xenial Xerus_ - Release amd64 (20160420.1)]/ xenial main restricted deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial main restricted deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-updates main restricted deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial universe deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-updates universe deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial multiverse deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-updates multiverse deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-security main restricted deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-security universe deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu/ xenial-security multiverse
     sudo apt-get update 更新源
       sudo apt-get upgrade 更新软件
安装nginx
apt-get install nginx
配置文件cd /etc/nginx/sites-available/defauder
    # Default server configuration
    server {
    listen 80 ;
    #listen [::]:80 default_server;
            root /var/www/html;
            # Add index.php to the list if you are using PHP
            index index.html index.htm index.nginx-debian.html;
            server_name _;
            location / {
                    # First attempt to serve request as file, then
                    # as directory, then fall back to displaying a 404.
                    #try_files $uri $uri/ =404;
                 try_files $uri $uri/ /index.php?$query_string;
            # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
            location ~ \.php$ {
                    include snippets/fastcgi-php.conf;
            # # With php7.0-cgi alone:
            # fastcgi_pass 127.0.0.1:9000;
            # # With php7.0-fpm:
                    fastcgi_pass unix:/run/php/php7.0-fpm.sock;
            # deny access to .htaccess files, if Apache's document root
            # concurs with nginx's one
            location ~ /\.ht {
             deny all;
安装php
安装mysql
apt-get install mysql-server mysql-client
sudo apt-get install php7.0-mbstring
sudo apt-get install curl
开始拉项目
成功之后修改权限
sudo chmod -R 777 storage/
sudo chmod -R 777 bootstrap/
sudo composer install
出现问题的话看一下什么问题有可能就是扩展没装
sudo apt-get install php7.0-dom
如果成功就生成key
php artisan key:gen
