Xcode 7 制作 framework (2)
打包提交到 App Store
在使用自制的 Framework 的应用程序打包提交到 App Store 的时候,可能会遇到以下问题“Unsupported architectures. Your executable contains unsupported architectures '[x86_64, i386]'”,此时在你要打包提交的目标程序的Build Phases下添加Run Script,并将以下内容复制进去:
    APP_PATH="${TARGET_BUILD_DIR}/${WRAPPER_NAME}"
    # This script loops through the frameworks embedded in the application and
    # removes unused architectures.
    find "$APP_PATH" -name '*.framework' -type d | while read -r FRAMEWORK
    do
    FRAMEWORK_EXECUTABLE_NAME=$(defaults read "$FRAMEWORK/Info.plist" CFBundleExecutable)
    FRAMEWORK_EXECUTABLE_PATH="$FRAMEWORK/$FRAMEWORK_EXECUTABLE_NAME"
    echo "Executable is $FRAMEWORK_EXECUTABLE_PATH"
    EXTRACTED_ARCHS=()
    for ARCH in $ARCHS
    do
    echo "Extracting $ARCH from $FRAMEWORK_EXECUTABLE_NAME"
    lipo -extract "$ARCH" "$FRAMEWORK_EXECUTABLE_PATH" -o "$FRAMEWORK_EXECUTABLE_PATH-$ARCH"
    EXTRACTED_ARCHS+=("$FRAMEWORK_EXECUTABLE_PATH-$ARCH")
    done
    echo "Merging extracted architectures: ${ARCHS}"
    lipo -o "$FRAMEWORK_EXECUTABLE_PATH-merged" -create "${EXTRACTED_ARCHS[@]}"
    rm "${EXTRACTED_ARCHS[@]}"
    echo "Replacing original executable with thinned version"
    rm "$FRAMEWORK_EXECUTABLE_PATH"
    mv "$FRAMEWORK_EXECUTABLE_PATH-merged" "$FRAMEWORK_EXECUTABLE_PATH"
    done
    复制代码
