把我设计中的设置贴上来,大家帮忙看看有没有问题
System contents:
base end
cpu 0x00301000 0x003017ff
fireware_rom 0x00301800 0x00301bff
data_ram 0x00301c00 0x00301fff
payload_buffer 0x00300000 0x00300fff
jtag_uart 0x00302030 0x00302037
sysid 0x00302030 0x0030203f
flash 0x00000000 0x001fffff
sram 0x00200000 0x002fffff
More "cpu" setting
reset address flash 0x00000000
exception address sram 0x00020000
break location cpu/jtag_debug_module 0x00000020
More "board_system" setting
hardware images
user flash ox00000000
safe flash 0x00080000
其中fireware_rom、data_ram、payload_buffer、jtag_uart、sysid是系统自动生成的可不可以删掉,用on_chip_memory代替
在执行run as--->niosII hardware时出项如下错误:
using cable "byteblasterII device,instance ox00
pausing target processor: not responding
resetting and trying again: falled
leaving target processor paused
请高手们看看以上设置有无问题,谢谢!
[此贴子已经被作者于2005-7-13 9:06:28编辑过] |
