打开SDK SHELL就提示:
bash.exe: warning: could not find /tmp, please create! bash: tr: command not found bash: uname: command not found bash: grep: command not found bash: cat: command not found bash: grep: command not found bash: sed: command not found bash: cat: command not found bash: grep: command not found bash: sed: command not found bash: uname: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found ------------------------------------------------ Welcome To Altera SOPC Builder
Version 5.00, Built Thu Mar 31 14:21:28 PST 2005 ------------------------------------------------ bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: grep: command not found bash: uname: command not found bash: grep: command not found
不能连接源文件。。
在NIOS IDE下,编译提示:
**** Incremental build of configuration Debug for project design_m ****
make -s all ´Ëʱ²»Ó¦ÓÐ "X`which cygpath.exe 2> /dev/null`"¡£ F:/nios2/components/altera_hal/build/app_rules.mk:152: `: No such file or directory F:/nios2/components/altera_hal/build/app_rules.mk:152: "F:/nios2"`: No such file or directory F:/nios2/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory F:/nios2/components/altera_hal/build/app_rules.mk:156: `: No such file or directory F:/nios2/components/altera_hal/build/app_rules.mk:156: "F:/nios2"`: No such file or directory F:/nios2/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop. Build completed
刚学这个,都不太懂。大家帮忙看看~~谢谢 |
