s3c2440的UART用法(4)
s3c2440的UART用法(4)
ADS下的串口配置
def.h 中的UART寄存器定义:
#define rULCON0     (*(volatile unsigned *)0x50000000) //UART 0 Line control
#define rUCON0      (*(volatile unsigned *)0x50000004) //UART 0 Control
#define rUFCON0     (*(volatile unsigned *)0x50000008) //UART 0 FIFO control
#define rUMCON0     (*(volatile unsigned *)0x5000000c) //UART 0 Modem control
#define rUTRSTAT0   (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status
#define rUERSTAT0   (*(volatile unsigned *)0x50000014) //UART 0 Rx error status
#define rUFSTAT0    (*(volatile unsigned *)0x50000018) //UART 0 FIFO status
#define rUMSTAT0    (*(volatile unsigned *)0x5000001c) //UART 0 Modem status
#define rUBRDIV0    (*(volatile unsigned *)0x50000028) //UART 0 Baud rate divisor
#define rULCON1     (*(volatile unsigned *)0x50004000) //UART 1 Line control
#define rUCON1      (*(volatile unsigned *)0x50004004) //UART 1 Control
#define rUFCON1     (*(volatile unsigned *)0x50004008) //UART 1 FIFO control
#define rUMCON1     (*(volatile unsigned *)0x5000400c) //UART 1 Modem control
#define rUTRSTAT1   (*(volatile unsigned *)0x50004010) //UART 1 Tx/Rx status
#define rUERSTAT1   (*(volatile unsigned *)0x50004014) //UART 1 Rx error status
#define rUFSTAT1    (*(volatile unsigned *)0x50004018) //UART 1 FIFO status
#define rUMSTAT1    (*(volatile unsigned *)0x5000401c) //UART 1 Modem status
#define rUBRDIV1    (*(volatile unsigned *)0x50004028) //UART 1 Baud rate divisor
#define rULCON2     (*(volatile unsigned *)0x50008000) //UART 2 Line control
#define rUCON2      (*(volatile unsigned *)0x50008004) //UART 2 Control
#define rUFCON2     (*(volatile unsigned *)0x50008008) //UART 2 FIFO control
#define rUMCON2     (*(volatile unsigned *)0x5000800c) //UART 2 Modem control
#define rUTRSTAT2   (*(volatile unsigned *)0x50008010) //UART 2 Tx/Rx status
#define rUERSTAT2   (*(volatile unsigned *)0x50008014) //UART 2 Rx error status
#define rUFSTAT2    (*(volatile unsigned *)0x50008018) //UART 2 FIFO status
#define rUMSTAT2    (*(volatile unsigned *)0x5000801c) //UART 2 Modem status
#define rUBRDIV2    (*(volatile unsigned *)0x50008028) //UART 2 Baud rate divisor
#ifdef __BIG_ENDIAN
#define rUTXH0      (*(volatile unsigned char *)0x50000023) //UART 0 Transmission Hold
#define rURXH0      (*(volatile unsigned char *)0x50000027) //UART 0 Receive buffer
#define rUTXH1      (*(volatile unsigned char *)0x50004023) //UART 1 Transmission Hold
#define rURXH1      (*(volatile unsigned char *)0x50004027) //UART 1 Receive buffer
#define rUTXH2      (*(volatile unsigned char *)0x50008023) //UART 2 Transmission Hold
#define rURXH2      (*(volatile unsigned char *)0x50008027) //UART 2 Receive buffer
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000023)=(unsigned char)(ch)
#define RdURXH0()   (*(volatile unsigned char *)0x50000027)
#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004023)=(unsigned char)(ch)
#define RdURXH1()   (*(volatile unsigned char *)0x50004027)
#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008023)=(unsigned char)(ch)
#define RdURXH2()   (*(volatile unsigned char *)0x50008027)
#define UTXH0       (0x50000020+3)  //Byte_access address by DMA
#define URXH0       (0x50000024+3)
#define UTXH1       (0x50004020+3)
#define URXH1       (0x50004024+3)
#define UTXH2       (0x50008020+3)
#define URXH2       (0x50008024+3)
#else //Little Endian
#define rUTXH0 (*(volatile unsigned char *)0x50000020) //UART 0 Transmission Hold
#define rURXH0 (*(volatile unsigned char *)0x50000024) //UART 0 Receive buffer
#define rUTXH1 (*(volatile unsigned char *)0x50004020) //UART 1 Transmission Hold
#define rURXH1 (*(volatile unsigned char *)0x50004024) //UART 1 Receive buffer
#define rUTXH2 (*(volatile unsigned char *)0x50008020) //UART 2 Transmission Hold
#define rURXH2 (*(volatile unsigned char *)0x50008024) //UART 2 Receive buffer
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
#define RdURXH0()   (*(volatile unsigned char *)0x50000024)
#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004020)=(unsigned char)(ch)
#define RdURXH1()   (*(volatile unsigned char *)0x50004024)
#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008020)=(unsigned char)(ch)
#define RdURXH2()   (*(volatile unsigned char *)0x50008024)
#define UTXH0       (0x50000020)    //Byte_access address by DMA
#define URXH0       (0x50000024)
#define UTXH1       (0x50004020)
#define URXH1       (0x50004024)
#define UTXH2       (0x50008020)
#define URXH2       (0x50008024)
#endif
Uart.c 文件中定义串口配置函数:
// 语法格式:void myUart_Init(int whichuart, int baud)
// 功能描述: 对Uart进行初始化,以所需要的波特率为输入参数
// 入口参数: UART端口号  波特率
// 出口参数: 无
void myUart_Init(int pclk, int baud)
if (pclk == 0)
    pclk = PCLK;
    if(UartNum == 0)        //判断是否使用UART0
/ /设置GPH端口为UART口
rGPHCON = rGPHCON & (~(0xffff));   //UART0: RXD0<==>GPH3  TXD0<==>GPH2
rGPHCON = rGPHCON | (0xaaa0) ;
    rGPHUP  = 0x0;                     //使能上拉功能
rUFCON0=0x00;   // 不使用FIFO
        rUMCON0=0x00;   //不使用自动流控制
        rULCON0=0x03;   //不采用红外线传输模式,无奇偶校验位,1个停止位,8个数据位
        rUCON0=0x245;
        rUBRDIV0=( (int)(pclk/16./baud+0.5) -1 );  //根据波特率计算UBRDIV0的值
  Delay(10);
     else if(UartNum == 1)
rGPHCON = rGPHCON & (~(0xffff)) ; //UART1: RXD1<==>GPH5  TXD1<==>GPH4
rGPHCON = rGPHCON | (0xaaa0) ;    //设置GPH端口为UART口
    rGPHUP  = 0x0;                    // 使能上拉功能
rUFCON1=0x0;
        rUMCON1=0x0;
        rULCON1=0x3;
        rUCON1=0x245;
        rUBRDIV1=( (int)(pclk/16./baud+0.5) -1 );
        Delay(10);
// 语法格式:void myUart_SendByte(char ch)
// 功能描述: 发送字节数据
// 入口参数: 发送的字节数据
// 出口参数: 无
if (UartNum ==0)
if(ch=='\n')
    while(!(rUTRSTAT0 & 0x2));  //等待,直到发送缓冲区为空
//     Delay(10);            //超级中断的响应速度较慢
    WrUTXH0('\r');              //发送回车符
// Delay(10);
WrUTXH0(ch);                    //发送字符
else
if(ch=='\n')
    while(!(rUTRSTAT1 & 0x2));   //等待,直到发送缓冲区为空
//     Delay(10);                 //等待
    rUTXH1='\r';
    while(!(rUTRSTAT1 & 0x2));  //Wait until THR is empty.
//     Delay(10);
    WrUTXH1(ch);
继承事业,薪火相传
