» 在emwin中显示字库芯片GT23L24M0140的字模
yuyang911220
286 小时
性别
男
yuyang911220
发表于 2015-3-28 09:20
环境:
主机:WIN8
开发环境:MDK5.13
mcu: stm32f407VGIGH6
emwin: STemWin5.22
字库芯片:GT23L24M0140
说明:
项目中需要显示生僻字,所以不能使用GB2312,选择字库芯片GT23L24M0140,支持GB18030标准。
难点在于在emwin中嵌入此字库芯片的字符,emwin本身有一套接口,所以必须满足这套接口才能显示。
解决的方法是先移植在emwin中显示sd卡/flash中字库的函数,然后将具体读取函数替换成直接读取字库芯片的函数。
字库芯片的驱动程序见此文:
驱动字库芯片GT23L24M0140
显示效果:
源代码:
GUI_UC_EncodeNone.c
[cpp]
view plain
copy
* uC/GUI
* Universal graphic software for embedded applications
* (c) Copyright 2002, Micrium Inc., Weston, FL
* (c) Copyright 2002, SEGGER Microcontroller Systeme GmbH
* 礐/GUI is protected by international copyright laws. Knowledge of the
* source code may not be used to write a similar product. This file may
* only be used in accordance with a license and should not be redistributed
* in any way. We appreciate your understanding and fairness.
File : GUI_UC_EncodeNone.c
Purpose : Encoding routines for non unicode systems (default)
---------------------------END-OF-HEADER------------------------------
//#include "GUI_Protected.h"
#include "GUI_Private.h"
* Static code
* _GetCharCode
* Purpose:
* Return the UNICODE character code of the current character.
static U16 _GetCharCode(const
char GUI_UNI_PTR * s) {
if((*s) > 0xA0)
return *(const U16 GUI_UNI_PTR *)s;
return *(const U8 GUI_UNI_PTR *)s;
* _GetCharSize
* Purpose:
* Return the number of bytes of the current character.
static
int _GetCharSize(const
GUI_USE_PARA(s);
if((*s) > 0xA0)
return 2;
return 1;
* _CalcSizeOfChar
* Purpose:
* Return the number of bytes needed for the given character.
static
int _CalcSizeOfChar(U16 Char) {
GUI_USE_PARA(Char);
if(Char > 0xA0A0)
return 2;
return 1;
* _Encode
* Purpose:
* Encode character into 1/2/3 bytes.
static
int _Encode(char *s, U16 Char) {
if(Char > 0xA0A0)
*((U16 *)s) = (U16)(Char);
return 2;
*s = (U8)(Char);
return 1;
* Static data
* _API_Table
const GUI_UC_ENC_APILIST GUI__API_TableNone = {
_GetCharCode, /* return character code as U16 */
_GetCharSize, /* return size of character: 1 */
_CalcSizeOfChar, /* return size of character: 1 */
_Encode /* Encode character */
* Exported code
* GUI_UC_SetEncodeNone
void GUI_UC_SetEncodeNone_User(void) {
GUI_LOCK();
//GUI_Context.pUC_API = &GUI__API_TableNone;
GUI_pUC_API = &GUI__API_TableNone;
GUI_UNLOCK();
继承事业,薪火相传
