- //将日期对象和向量对象写入文件,然后从文件中读出并输出到屏幕上,
- package objstream;
- import java.io.File;
- import java.io.FileInputStream;
- import java.io.FileNotFoundException;
- import java.io.FileOutputStream;
- import java.io.IOException;
- import java.io.ObjectInputStream;
- import java.io.ObjectOutputStream;
- import java.util.Date;
- import java.util.Vector;
- import java.util.logging.Level;
- import java.util.logging.Logger;
- import javafx.scene.chart.PieChart.Data;
- * @author Administrator
- public
class ObjStream {
- * @param args the command line arguments
- public
static
void main(String[] args) throws IOException { - try {
- //这2句与FileOutputStream fout = new FileOutputStream("test.txt");
- //是等价的
- FileOutputStream fout = null;
- File f = new File("test.txt");
- Vector v = new Vector(); //Vector变量
- v.add("不求有功");
- v.add("才华出众");
- v.add("瞬息万变");
- fout = new FileOutputStream(f);
- ObjectOutputStream Obj = new ObjectOutputStream(fout);
- Object Oj = new Object();
- Oj = new Date();
- Obj.writeObject(Oj);
- Obj.writeObject(v);
- Obj.close();
- FileInputStream Fin = new FileInputStream(f);
- ObjectInputStream Ois = new ObjectInputStream(Fin);
- Object Oji = new Object(); //这里为什么要用2个OBJECT来输出求指教
- Oji = Ois.readObject(); //不用2个的话只输出时间
- System.out.println(Oji);
- Object Oji2 = new Object();
- Oji2 = Ois.readObject();
- System.out.println(Oji2);
- } catch (FileNotFoundException ex) {
- Logger.getLogger(ObjStream.class.getName()).log(Level.SEVERE, null, ex);
- } catch (ClassNotFoundException ex) {
对象输入流)可读取使用对象输出流写入的原始数据和类型,与文件输入输出流一起可以实现对象的持久性存储。
结果:
Fri Jul 24 11:28:01 CST 2015
[不求有功, 才华出众, 瞬息万变]
成功构建 (总时间: 2 秒)
但是test.txt文件里是乱码~~怎么破?? |
