JDB 的简单使用(1)
JDB 的简单使用(1)
[size=1.0625]首先我们写一个最简单的小程序,但是它包含了一些最基本的面向对象要素。
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875]5
[size=0.875]6
[size=0.875]7
[size=0.875]8
[size=0.875]9
[size=0.875]10
[size=0.875]11
[size=0.875]12
[size=0.875]13
[size=0.875]14
[size=0.875]15
[size=0.875]16
[size=0.875]17
[size=0.875]18
[size=0.875]19
[size=0.875]20
[size=0.875]21
[size=0.875]22
[size=0.875]23
[size=0.875]24
[size=0.875][size=0.875]class test
[size=0.875]{
[size=0.875]    int a;
[size=0.875]    int b;
[size=0.875]    test(int aa,int bb)
[size=0.875]    {
[size=0.875]        a = aa;
[size=0.875]        b = bb;
[size=0.875]        }
[size=0.875]    int add()
[size=0.875]    {return a+b;}
[size=0.875]}
[size=0.875]public class hehe
[size=0.875]{
[size=0.875]    public static void main(String args[])
[size=0.875]    {
[size=0.875]        int a = 2;
[size=0.875]        int b = 3;
[size=0.875]        int c= a+b;
[size=0.875]        System.out.println(c);
[size=0.875]        test kk=new test(1,2);
[size=0.875]        System.out.println(kk.add());
[size=0.875]    }
[size=0.875]}
[size=1.0625]存为hehe.java后,用javac -g hehe.java进行编译。用参数g是为了产生各种调试信息,不用就无法调试。如果这里遇到问题,请参考Helloworld攻略。上面的程序是可以通过的,可以直接用java hehe运行。下面结合该例子谈谈JDB的使用。
[size=1.0625]首先键入jdb hehe 如果出现下面信息,说明系统没有找到调试的类。此时可以用java -classpath . hehe命令解决。
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875][size=0.875]C:\javasource>jdb hehe
[size=0.875]Initializing jdb...
[size=0.875]hehe not found
[size=0.875]>
[size=1.0625]如果出现一下信息,说明开始进行调试,一切正常。如果是调试Applet,则用 appletviewer -debug hehe.html命令进行调试
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875][size=0.875]C:\javasource>jdb -classpath . hehe
[size=0.875]0xb0:class(hehe)
[size=0.875]>
[size=1.0625]回想VC中的调试,应该是设置断点,然后再进行跟踪。Java中也是一样。用stop命令进行断点设置。然后用 run 命令开始调试,运行程序到断点,这里断点是设置在 main 主函数中。
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875]5
[size=0.875]6
[size=0.875]7
[size=0.875]8
[size=0.875][size=0.875]> stop at hehe:18
[size=0.875]Breakpoint set at hehe:18
[size=0.875]> run
[size=0.875]run hehe
[size=0.875]running ...
[size=0.875]main[1]
[size=0.875]Breakpoint hit: hehe.main (hehe:18)
[size=0.875]main[1]
[size=1.0625]此时可以用locals命令查看变量,用step命令进入下一条命令,也可以用单独一个stop命令来查看断点的设置情况。注意此时b还没有被赋值。
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875]5
[size=0.875]6
[size=0.875]7
[size=0.875]8
[size=0.875]9
[size=0.875][size=0.875]main[1] locals
[size=0.875]Method arguments:
[size=0.875]Local variables:
[size=0.875]  args =
[size=0.875]  a = 2
[size=0.875]main[1] step
[size=0.875]main[1]
[size=0.875]Breakpoint hit: hehe.main (hehe:19)
[size=0.875]main[1]
[size=1.0625]当运行到 System.out.println() 函数时,会出现以下提示:
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875][size=0.875]main[1] step
[size=0.875]main[1]
[size=0.875]Breakpoint hit: java.lang.ClassLoader.loadClass (ClassLoader:247)
[size=1.0625]这个是因为我们跟踪进去了 println 方法,我们一般没有必要这样做,此时可以用next跳过该方法进入到下一条一句。step的含义是进入函数跟踪,next是转入下一条语句执行。我们随时可以键入 locals 和 list 命令来查看变量值和当前运行的代码。下面箭头指到地方即为当前程序运行到的地方。
[size=0.875]1
[size=0.875]2
[size=0.875]3
[size=0.875]4
[size=0.875]5
[size=0.875]6
[size=0.875]7
[size=0.875]8
[size=0.875]9
[size=0.875]10
[size=0.875]11
[size=0.875]12
[size=0.875]13
[size=0.875]14
[size=0.875][size=0.875]main[1] next
[size=0.875]main[1]
[size=0.875]Breakpoint hit: hehe.main (hehe:20)
[size=0.875]main[1] list
[size=0.875]16              {
[size=0.875]17                      int a = 2;
[size=0.875]18                      int b = 3;
[size=0.875]19                      int c= a+b;
[size=0.875]20      =>              System.out.println(c);
[size=0.875]21                      test kk=new test(1,2);
[size=0.875]22                      System.out.println(kk.add());
[size=0.875]23
[size=0.875]24              }
[size=0.875]main[1]
山不在高,有仙则名;水不在深,有龙则灵。
