一种基于ARM-Linux的FPGA程序加载方法(2)
4、嵌入式 Linux的驱动实现
本文以模块形式实现了运行于S3C2410上的linux驱动程序,源文件如下(有关寄存器的设置参考S3C2410的数据手册,以下源代码未包含头文件):
  #define GPIO_va_base 0x0F6000000
  //基于S3C2410 上的Linux内核IO控制寄存器首地址映射后的虚拟地址
  #define ARM_GPDCON PIO_va_base+0x30);
  #define ARM_GPDUP PIO_va_base+0x38);
  #define ARM_port_wr(addr,value) *(volatile unsigned int*)(addr)=value)
  //定义输出
  #define FPGA_CS 8
  #define FPGA_RW 9
  #define FPGA_PROG 12
  #define FPGA_CCLK 14
  //定义操作
  #define ARM_GPDDAT (*(volatile u32 *)(GPIO_va_base+0x34))
  #define set_register_bit(x) ARM_GPDDAT=(1<<x)|arm_gpddat</x)|arm_gpddat
  #define clear_register_bit(x) ARM_GPDDAT=(~(1<<x))&arm_gpddat</x))&arm_gpddat
  //定义输入
  #define FPGA_INIT ((ARM_GPDDAT>>10)&1)
  #define FPGA_BUSY ((ARM_GPDDAT>>11)&1)
  #define FPGA_DONE ((ARM_GPDDAT>>13)&1)
  #define FPGA 211
  //定义主设备号,和mknod /dev/fpga c 211 0匹配
  typedef char fpga_device_t;
  static fpga_device_t fpga_devices[257];
  char buf[1000000];
  int fpga_open(struct inode *, struct file *);
  ssize_t fpga_write(struct file *,const char *,size_t ,loff_t *);
  int fpga_release(struct inode*, struct file *);
  //初始化ARM的D组通用IO管脚
  void init_fpga(void){
  ARM_port_wr(GPIO_va_base+0x30,0x55555555);
  //FPGA_BUSY FPGA_DONE FPGA_INIT be set input
  ARM_port_wr(GPIO_va_base+0x34,0xFFFF);
  ARM_port_wr(GPIO_va_base+0x30,0x51055555);
  ARM_port_wr(GPIO_va_base+0x38,0);// put up
  set_register_bit(FPGA_CCLK);//set GCLK
  static struct file_operations fpga_ctl_fops= {
  open: fpga_open,
  write: fpga_write,
  release: fpga_release,};
  int init_module(void) {
  printk("Hello,word,Now preparing FPGA......\n");
  printk("register FPGA......\n");
  register_chrdev(FPGA, "fpga", &fpga_ctl_fops);
  printk("Done!\n");
  printk("Hello,word,success!\n");
  return 0;
  int fpga_open(struct inode *inode, struct file *filp){
  int minor;
  minor = MINOR(inode->i_rdev);
  init_fpga();
  fpga_devices[minor]++;
  printk("FPGA is ready.\n");
  return 0;
  ssize_t fpga_write(struct file *flip,const char *buffer,size_t count,loff_t
  *ppos){
  int i;
  if(copy_from_user(buf,buffer,count)){
  printk("error \n");
  return -EFAULT;
  printk("%d numbers have been received!\n",count);
  printk("The number is:%d\n",count);
  for(i=0;i<count;i++){</count;i++){
  ARM_GPDDAT=(ARM_GPDDAT&0x3F00)|buf;
  printk("data write finished\n");
  for(i=0;i<4;i++){
  clear_register_bit(FPGA_CCLK);
  return count;
  int fpga_release(struct inode *inode, struct file *filp){
  int minor;
  if (fpga_devices[minor])
  fpga_devices[minor]--;
  printk("Goodbye cruel world\n");
  return 0;
  void cleanup_module(void){
5、结束语
  本文的创新点:基于ARM-Linux平台,实现了一种FPGA的程序加载模式,加载速度快,灵活高效。
