多人协作时gradle配置优化(4)
多人协作时gradle配置优化(4)
gradle.properties文件
    # Project-wide Gradle settings.
    # IDE (e.g. Android Studio) users:
    # Gradle settings configured through the IDE *will override*
    # any settings specified in this file.
    # For more details on how to configure your build environment visit
    # http://www.gradle.org/docs/curre ... ld_environment.html
    # Specifies the JVM arguments used for the daemon process.
    # The setting is particularly useful for tweaking memory settings.
    org.gradle.jvmargs=-Xmx1536m
    # When configured, Gradle will run in incubating parallel mode.
    # This option should only be used with decoupled projects. More details, visit
    # http://www.gradle.org/docs/curre ... :decoupled_projects
    # org.gradle.parallel=true
    #android插件版本号,一般与android studio版本号一致
    androidPluginVer=3.1.2
    #编译sdk版本号
    sdkVersion=26
