ab 测试
ab 测试
1、做压力测试的工具:ab
2、性能的监控工具:nmon
    查看下linux主机上的ulimit -n 的数据,没有改动过的是1024,最好要改的大一点。这个是linux下最大线程数,如果过小的话无法进行大并量的测试。
    ab经行压力测试时的脚本我用的形式为:
1.(get方式)./ab -n 1000 -c 1000 -k http://localhost/hello.php
2.(post方式./ab -n 2500 -c 2500 -k -p postfile http://localhost/hello.php
其中参数n为请求的次数,c为一次请求的并发次数,-k为keep_alive,一般出现链接被重置的错误时最好带上-k的参数。
还有好多参数,可以在ab--help中看下(这个是超级秘籍)。
[php] view plain copy
Usage: ab [options] [http[s]://]hostname[:port]/path
Options are:
    -n requests     Number of requests to perform
    -c concurrency  Number of multiple requests to make
-t timelimit    Seconds to max. waitfor responses
    -b windowsize   Size of TCP send/receive buffer, in bytes
    -p postfile     File containing data to POST. Remember also to set -T
    -u putfile      File containing data to PUT. Remember also to set -T
-T content-type Content-type headerfor POSTing, eg.
'application/x-www-form-urlencoded'
Default is'text/plain'
    -v verbosity    How much troubleshooting info to print
    -w              Print out results in HTML tables
    -i              Use HEAD instead of GET
-x attributes   String to insertas table attributes
-y attributes   String to insertas tr attributes
-z attributes   String to insertas td or th attributes
    -C attribute    Add cookie, eg. 'Apache=1234. (repeatable)
-H attribute    Add Arbitrary header line, eg.'Accept-Encoding: gzip'
                    Inserted after all normal header lines. (repeatable)
    -A attribute    Add Basic WWW Authentication, the attributes
are a colon separated usernameand password.
    -P attribute    Add Basic Proxy Authentication, the attributes
-X proxy:port   Proxyserverand port number to use
-V              Print version numberand exit
    -k              Use HTTP KeepAlive feature
    -d              Do not show percentiles served table.
-S              Do not show confidence estimatorsand warnings.
    -g filename     Output collected data to gnuplot format file.
    -e filename     Output CSV file with percentages served
-r              Don'texit on socket receive errors.
    -h              Display usage information (this message)
    -Z ciphersuite  Specify SSL/TLS cipher suite (See openssl ciphers)
-f protocol     Specify SSL/TLS protocol (SSL2, SSL3, TLS1,or ALL)
