EventBus源码分析(4)
EventBus源码分析(4)
post:就是把event,其实就是传入的 Javabean数据 , 保存在当前线程的 PostingThreadState 的 eventQueue队列 中
1>:首先:判断当前是否是主线程;
2>:然后:遍历 eventQueue队列中所有的 event,其实就是遍历所有 post(param) 中传递的参数,然后调用 postSingleEvent
    private void postSingleEvent(Object event, PostingThreadState postingState) throws Error {
            // 获取当前 Javabean数据 所在的 Class对象
            Class<? extends Object> eventClass = event.getClass();
            // 根据eventClass获取 List<Class<?>>,其实就是 Javabean数据 的当前Class、
            // 及父类和接口的Class类型,用于匹配
            // eventTypes:是所有 Class
            List<Class<?>> eventTypes = findEventTypes(eventClass);
            boolean subscriptionFound = false;
            // 遍历所有Class,在 subscriptionsByEventType中 查找 subscriptions ,
            // register注册:就是把 所有方法都存储到 subscriptionsByEventType集合中
            int countTypes = eventTypes.size();
            for (int h = 0; h < countTypes; h++) {
                Class<?> clazz = eventTypes.get(h);
                CopyOnWriteArrayList<Subscription> subscriptions;
                synchronized (this) {
                    subscriptions = subscriptionsByEventType.get(clazz);
                if (subscriptions != null && !subscriptions.isEmpty()) {
                    // 遍历每个 subscription ,依次调用 postToSubscription
                    for (Subscription subscription : subscriptions) {
                        postingState.event = event;
                        postingState.subscription = subscription;
                        boolean aborted = false;
                        try {
                            postToSubscription(subscription, event, postingState.isMainThread);
                            aborted = postingState.canceled;
                        } finally {
                            postingState.event = null;
                            postingState.subscription = null;
                            postingState.canceled = false;
                        if (aborted) {
                            break;
                    subscriptionFound = true;
            if (!subscriptionFound) {
                if (eventClass != NoSubscriberEvent.class && eventClass != SubscriberExceptionEvent.class) {
                    post(new NoSubscriberEvent(this, event));
