手动安装ceph和使用(6)
手动安装ceph和使用(6)
[ceph3][DEBUG ] ******************************************************************************** [ceph3][DEBUG ] status for monitor: mon.ceph3 [ceph3][DEBUG ] { [ceph3][DEBUG ] "election_epoch": 1, [ceph3][DEBUG ] "extra_probe_peers": [ [ceph3][DEBUG ] "192.168.199.81:6789/0", [ceph3][DEBUG ] "192.168.199.82:6789/0" [ceph3][DEBUG ] ], [ceph3][DEBUG ] "monmap": { [ceph3][DEBUG ] "created": "0.000000", [ceph3][DEBUG ] "epoch": 0, [ceph3][DEBUG ] "fsid": "93cfef7e-98a5-440f-af59-1a950e283b74", [ceph3][DEBUG ] "modified": "0.000000", [ceph3][DEBUG ] "mons": [ [ceph3][DEBUG ] { [ceph3][DEBUG ] "addr": "192.168.199.81:6789/0", [ceph3][DEBUG ] "name": "ceph1", [ceph3][DEBUG ] "rank": 0 [ceph3][DEBUG ] }, [ceph3][DEBUG ] { [ceph3][DEBUG ] "addr": "192.168.199.82:6789/0", [ceph3][DEBUG ] "name": "ceph2", [ceph3][DEBUG ] "rank": 1 [ceph3][DEBUG ] }, [ceph3][DEBUG ] { [ceph3][DEBUG ] "addr": "192.168.199.83:6789/0", [ceph3][DEBUG ] "name": "ceph3", [ceph3][DEBUG ] "rank": 2 [ceph3][DEBUG ] } [ceph3][DEBUG ] ] [ceph3][DEBUG ] }, [ceph3][DEBUG ] "name": "ceph3", [ceph3][DEBUG ] "outside_quorum": [], [ceph3][DEBUG ] "quorum": [], [ceph3][DEBUG ] "rank": 2, [ceph3][DEBUG ] "state": "electing", [ceph3][DEBUG ] "sync_provider": [] [ceph3][DEBUG ] } [ceph3][DEBUG ] ******************************************************************************** [ceph3][INFO  ] monitor: mon.ceph3 is running [ceph3][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph3.asok mon_status [ceph_deploy.mon][INFO  ] processing monitor mon.ceph1 [ceph1][DEBUG ] connected to host: ceph1 [ceph1][DEBUG ] detect platform information from remote host [ceph1][DEBUG ] detect machine type [ceph1][DEBUG ] find the location of an executable [ceph1][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph1.asok mon_status [ceph_deploy.mon][WARNIN] mon.ceph1 monitor is not yet in quorum, tries left: 5 [ceph_deploy.mon][WARNIN] waiting 5 seconds before retrying [ceph1][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph1.asok mon_status [ceph_deploy.mon][INFO  ] mon.ceph1 monitor has reached quorum! [ceph_deploy.mon][INFO  ] processing monitor mon.ceph2 [ceph2][DEBUG ] connected to host: ceph2 [ceph2][DEBUG ] detect platform information from remote host [ceph2][DEBUG ] detect machine type [ceph2][DEBUG ] find the location of an executable [ceph2][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph2.asok mon_status [ceph_deploy.mon][INFO  ] mon.ceph2 monitor has reached quorum! [ceph_deploy.mon][INFO  ] processing monitor mon.ceph3 [ceph3][DEBUG ] connected to host: ceph3 [ceph3][DEBUG ] detect platform information from remote host [ceph3][DEBUG ] detect machine type [ceph3][DEBUG ] find the location of an executable [ceph3][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph3.asok mon_status [ceph_deploy.mon][WARNIN] mon.ceph3 monitor is not yet in quorum, tries left: 5 [ceph_deploy.mon][WARNIN] waiting 5 seconds before retrying [ceph3][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph3.asok mon_status [ceph_deploy.mon][WARNIN] mon.ceph3 monitor is not yet in quorum, tries left: 4 [ceph_deploy.mon][WARNIN] waiting 10 seconds before retrying [ceph3][INFO  ] Running command: ceph --cluster=ceph --admin-daemon /var/run/ceph/ceph-mon.ceph3.asok mon_status [ceph_deploy.mon][INFO  ] mon.ceph3 monitor has reached quorum! [ceph_deploy.mon][INFO  ] all initial monitors are running and have formed quorum [ceph_deploy.mon][INFO  ] Running gatherkeys... [ceph_deploy.gatherkeys][INFO  ] Storing keys in temp directory /tmp/tmpaZC0NP [ceph1][DEBUG ] connected to host: ceph1 [ceph1][DEBUG ] detect platform information from remote host [ceph1][DEBUG ] detect machine type [ceph1][DEBUG ] get remote short hostname [ceph1][DEBUG ] fetch remote file [ceph1][INFO  ] Running command: /usr/bin/ceph --connect-timeout=25 --cluster=ceph --admin-daemon=/var/run/ceph/ceph-mon.ceph1.asok mon_status [ceph1][INFO  ] Running command: /usr/bin/ceph --connect-timeout=25 --cluster=ceph --name mon. --keyring=/var/lib/ceph/mon/ceph-ceph1/keyring auth get client.admin [ceph1][INFO  ] Running command: /usr/bin/ceph --connect-timeout=25 --cluster=ceph --name mon. --keyring=/var/lib/ceph/mon/ceph-ceph1/keyring auth get client.bootstrap-mds [ceph1][INFO  ] Running command: /usr/bin/ceph --connect-timeout=25 --cluster=ceph --name mon. --keyring=/var/lib/ceph/mon/ceph-ceph1/keyring auth get client.bootstrap-osd [ceph1][INFO  ] Running command: /usr/bin/ceph --connect-timeout=25 --cluster=ceph --name mon. --keyring=/var/lib/ceph/mon/ceph-ceph1/keyring auth get client.bootstrap-rgw [ceph_deploy.gatherkeys][INFO  ] Storing ceph.client.admin.keyring [ceph_deploy.gatherkeys][INFO  ] Storing ceph.bootstrap-mds.keyring [ceph_deploy.gatherkeys][INFO  ] keyring 'ceph.mon.keyring' already exists [ceph_deploy.gatherkeys][INFO  ] Storing ceph.bootstrap-osd.keyring [ceph_deploy.gatherkeys][INFO  ] Storing ceph.bootstrap-rgw.keyring [ceph_deploy.gatherkeys][INFO  ] Destroy temp directory /tmp/tmpaZC0NP Error in sys.exitfunc: [zzq@localhost myceph]$
