imx31和imx51的区别以及imx51研讨会信息
欢迎广大电子工程师和工程技术人员参加20091021由中电网和飞思卡尔半导体共同举办的用飞思卡尔i.MX51迎接移动互联网的来临在线技术座谈(网址:http://seminar.ECCN.com/)。
i.mx51的性能
ARM CORTEX A8
主频高达 1G
Multimedia
_ Encode – D1 30fps (MPEG4 SP, H.264 BP, MJPEG)
_ Decode – HD720 30fps (MPEG2 MP, MPEG4 ASP, H.264 HP,
VC-1 AP, DivX, RV10)
_ Graphics – OpenVG1.1, OpenGL ES 2.0 @ 27M Tri/sec
_ TV Encoder – Component, Composite or S-Video out at 720p
Camera
_ Camera and Display I/F (legacy
_ Image Sensor Processor (ISP)
_ Up to 8Mpixel @ 15fps, Up 133Mpixel/sec
_ Resizing, Inversion, Rotation
_ Color Space conversion, video/graphics combining
Display
_ Display I/F (legacy and MIPI DSI)
_ Up to WXGA display - 24 bit @ 60fps
_ Secondary Display Support
Connectivity
_ High speed USB OTG w/ embedded Phy, Host HS x3
_ Up to 400Mbps MobileDDR, DDR2
_ SLC/MLC NAND Flash 8/16-bit, NAND/NOR
_ High speed MMC\SDIO, UART, I2C, SPI
_ ATA-6
_ 3.3V support on HD, SDIO, and SIM I/F
Security
_ TrustZone
_ AES, DES/3DES, SHA-1, SHA-224, SHA-256
_ Run time integrity checker (RTICv3)
_ Secure High Assurance Boot
_ Security Controller (SCC), including Secure RAM and
Security Monitor
_ Random Number Generator Accelerator (RNGA)
_ Secure JTAG Controller (with electrical fuses)
_ Secure real-time clock
_ Universal Unique Identification
_ Tamper Detection
Power Management
_ Advanced power management (DVFS, DPTC)
_ State retention power gating
_ Multiple independent clock and power domains
相对i.MX35而言,i.MX51在以下几个方面有大幅提升:
1. ARM core:
i.MX51用的是ARM Cotex A8, i.MX35采用的是ARM11. i.MX51的L1,L2 Cache容量更大,ARM主频更高,最高可达1GHz. 故处理能力更强。
2. 多媒体硬件加速:
i.MX51内部有硬件video codec,支持多达8种视频解码,和4种视频编码。解码分辨率最高到720p 30f/s, 编码分辨率最高到D1 30f/s. 也就是说是市面上有的视频几乎都能解。另外它还加入了3D graphics硬件加速,可以轻松对游戏场景进行3维渲染。
而i.MX35不含硬件video codec和3D graphics,只含2D graphics HW accelarator.
3. 外围接口
两款芯片在外围接口的支持上,都做得非常细致和全面。只是稍有区别,比如,i.MX51支持HS I2C,而i.MX35只支持到fast mode; i.MX51支持3个USB2.0 hosts, 1个USB2.0 OTG, i.MX35只支持1个USB2.0 hosts, 1个USB2.0 OTG.
可见,i.MX51是一款针对多媒体市场的非常powerful的芯片,而i.MX35则是针对汽车电子,工控市场的非常实用的芯片。两者针对市场不同,特点不同,但是都是非常优秀的产品。
作为应用处理器领先企业的飞思卡尔半导体,适时地推出了i.MX51系列应用处理器, 来迎接移动互联网的来临.i.MX51应用处理器采用ARM Cortex A8内核,集成了两个GPU,分别处理2D和3D图形运算;内嵌的VPU(视频处理单元)可以在CPU占用率非常低的情况下处理各种规格的高清视频;更重要的是,i.MX51芯片的功耗极低.i.MX51提供了"移动计算","移动娱乐"和"移动通讯"全方位的解决方案,可以令你的产品在移动互联网时代璀灿夺目,脱颖而出.
飞思卡尔公司诚挚邀请广大电子工程技术人员踊跃参加本次在线研讨会。届时,我们的专家将和您网上实时交流,并且现场解答您所提出的相关技术问题。
更有多重好礼等你拿,赶快报名吧!
1.凡实时登录参加此次在线座谈并提问,有效问题*数量达到5条,即可得到精美真皮护照包一个(共5份,获奖者将在达到条件的观众中随机抽取)。
2.凡实时登录参加此次在线座谈并提问,有效问题*数量达到10条,即可得到Digital wallets一个(共5份,获奖者将在达到条件的观众中随机抽取)
提前报名登录,按时参会,并达到相应的要求,就可获得中电网提供的新、奇、特电子类及生活类奖品,奖品共有六种,奖品数量不设上限,
奖品设置如下, 详细奖品信息请参考:奖品信息
1.
收纳盒,价值20
2.
音乐抱枕,价值:30元。
3.
最新款电脑USB跳舞毯一个,价值:80
4.
酷冷至尊(CoolerMaster)尊龙笔记本散热器一个。价值:100元。
5.
无线鼠标,价值:200元。
6.
数码相框,价值:500元。
