32位定点补码整数加减交替法
32位定点补码整数加减交替法
定点补码整数加减交替法:
1.操作数的预置:除数装入Y寄存器,被除数装入Z,X寄存器,被除数须以2n位补码形式表示
2.
Z,X左移1
3.
ZY同号,则计算Z=Z+[-Y];否则计算Z=Z+[-Y]补;根据计算结果,按以下规则确定商值X[0]:
Z,X=0Z操作前后符号未变,则X[0]1,转下一步;
A操作前后符号已变,则X[0]0,恢复Z值,转下一步;
4.重复(2)(3)两步,直到取得n位商为止。
5.余数在Z中。若被除数与除数同号,则商在X中;否则,[-X]是真正的商。
module div32(
done,
c,
d,
a,
b,
start,
clk
parameter N=32;
output done;
output [N-1:0]c;
output [N-1:0]d;
input [2*N-1:0]a;
input [N-1:0]b;
input start;
input clk;
reg [5:0]index;
reg [N-1:0]z;
reg [N-1:0]temp_z;
reg [N-1:0]x;
reg [N-1:0]y;
reg [N-1:0]y_c;
reg finished;
reg [1:0]current_state,next_state;
parameter Init=0,Load=1,Acc=2,Done=3;
always @(posedge clk or negedge start)
if (!start)
  current_state<=Init;
else
  current_state<=next_state;
always @(current_state or index)
case (current_state )
Init :
  begin
   next_state=Load;
  end
Load:
  begin
   next_state=Acc;
  end
Acc :
  begin
   if(index==6'h1f)
    begin
     next_state=Done;
    end
  end
endcase
case (current_state)
Init:
  begin
   finished=0;
  end
Load:
  begin
   {z[N-1:0],x[N-1:0]}=a;
   y=b;
   y_c=~b+1;
   $display("z=%b,x=%b,y=%b,y_c=%b",z,x,y,y_c);
  end
Acc:
  begin
   $display("Before left shift:z=%b,x=%b",z,x);
   {z[N-1:0],x[N-1:0]}={z[N-2:0],x[N-1:0],1'b0};
   temp_z=z;
   $display("After left shift:z=%b,x=%b",z,x);
   if(z[N-1]==y[N-1])
    begin
     z=z+y_c;
     $display("Same-After adding :z=%b,x=%b",z,x);
    end
   else
    begin
     z=z+y;
     $display("Different-After adding y:z=%b,x=%b",z,x);
    end
   if(temp_z[N-1]==z[N-1])
   begin
    x[0]=1;
    $display("After get a bit 1 :z=%b,x=%b",z,x);
   end
   else
   begin
    x[0]=0;
    z=temp_z;
    $display("After get a bit 0 :z=%b,x=%b",z,x);
   end
  end
default:
  begin
   finished=1;
   $display("c=%b",c);
  end
endcase
always @(posedge clk)
if (current_state==Acc)
  index<=index+1;
else
  index<=0;
assign done=finished;
assign c[N-1:0]=(a[N-1]==b[N-1])?x[N-1:0]~x[N-1:0]+1);
assign d=z;
endmodule
module test_div32_v;
        // Inputs
        reg [63:0] a;
        reg [31:0] b;
        reg start;
        reg clk;
        // Outputs
        wire done;
        wire [31:0] c;
        wire [31:0]d;
        // Instantiate the Unit Under Test (UUT)
        div32 uut (
                .done(done),
                .c(c),
                .d(d),
                .a(a),
                .b(b),
                .start(start),
                .clk(clk)
        initial begin
                // Initialize Inputs
                a = 0;
                b = 0;
                start = 0;
                clk = 0;
                // Wait 100 ns for global reset to finish
                #100;
      start=1;
                // Add stimulus here
                a=27;
                b=3;
                a=100;
                b=23;
                a=-100;
                b=23;
//                a=100;
//                b=-23;
        end
   always #10 clk=~clk;
endmodule
