pic168xa ADC程序(c语言)
#i nclude <pic.h>
#i nclude <pic168xa.h>
__CONFIG(0x1832);
//芯片配置字,看门狗关,上电延时开,掉电检测关,低压编程关,加密,4M晶体HS振荡
const char TABLE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void DELAY();
void DELAY11();
void init();
void display(unsigned int x);
void main()
{unsigned int result=0x0000;
do
int i;
result=0x0000;
//for(i=4;i--;)
init();
DELAY();
ADGO=0X01;
while(ADGO)
{result=ADRESH;
result=result<<8;
result=result+ADRESL;};
// result=result>>3;
for(i=10;--i;)
{display(result);};
//DELAY11();};
}while(1);
void init()
TRISD=0X00;
TRISB=0XE1;
PORTD=0X00;
ADCON1=0X8E;
ADCON0=0XC1;
DELAY();
{int qian,bai,shi,ge;
unsigned int temp;
temp=x;
qian=temp/0x3e8;
PORTD=TABLE[qian]; //查表得百位显示的代码
PORTB=0xef; //RA3输出低电平,点亮百位显示
// DELAY11();
bai=(temp%0x3e8)/0x64;
PORTD=TABLE[bai]; //查表得百位显示的代码
PORTB=0xf7; //RA3输出低电平,点亮百位显示
//DELAY11();
shi=((temp%0x3e8)%0x64)/0xa; //延时一定时间,保证显示亮度
PORTD=TABLE[shi]; //查表得十位显示的代码
PORTB=0xfb; //RA4输出低电平,点亮十位显示
//DELAY11();
ge=((temp%0x3e8)%0x64)%0xa; //延时一定时间,保证亮度
PORTD=TABLE[ge]; //求个位显示的代码
PORTB=0xfd; //RA5输出低电平,点亮个位显示
DELAY11();
void DELAY()
int i;
for(i=0x100;i--;);
void DELAY11()
int i;
for(i=0;i<=30;i++)
continue;
