由于公司需要,我刚接触nios两天!我安装了quartusII 5。0和nioseII 5。0从niose网站下载了unlinux1.4,我用的开发板是ep2s60,
创建的kernel工程都是默认配置,选择的pf是e'p'2s60f , linux虽然编译成功,但是,update出错,请各路高手帮帮忙
我是编译后就update操作的,没有再做其他操作!
我还不知道它是怎么运行的,是否需要bootloader?
update后出现这种错误
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
Aug 29, 2005 11:42:10 AM - (??) nios2-flash-programmer: Launching Quartus Progra
mmer to download:
c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es/syste
m/altera_nios_dev_board_stratix_2s60_es.sof
Unable to synchronize with target.
Aug 29, 2005 11:43:14 AM - (??) nios2-flash-programmer: Error opening target har
dware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
WARNING: Default charset GBK not supported, using ISO-8859-1 instead |
