Benefits of Invisible Hair Extensions
Despite the artificial placing of this man made skin, your hair will continue to grow undamaged. It is placed on your scalp without any cutting or shaving of your original Curly Full Lace Wigs. Polyurethane skin base can easily be altered for a custom size or shape to suit your need. So need not worry of the tiny or the big spot. All can be taken care of! The best part is that it looks just like your hair is growing. The adhesive is of a neutral skin tone that matches most of the skin types. This is the most "natural looking" man made hair extension you can have. Each Invisible Straight Full Lace Wigs Addition has between 2-6 separate colors blended in either a tone-on-tone or subtle highlight combination. There are no pins, no aches, no bumps to make it uncomfortable. The application is smooth and you can easily sleep with them. You will actually forget they are there in the first place,hair extensions! A man made skin replica, with one smooth side for attaching to clients scalp and the other side having one hair at a time secured to the skin in order to imitate naturally growing hair. Can be attached anywhere on the head which allows a stylist to design a custom application. So, why worry when you are noticing the fall of human hair lace front wigs from noticeable places like the temples and the crown – go to the nearest salon offering this service, and come home worry free! The best thing about extensions is that it allows you to have the desired hair length, and the hair thickness that you always wanted in one visit to the salon. Don't worry if you have lost hair on the sides, crown or the temple. There is help available – there are hair studios in Toronto who can take care of your worries leaving you looking smashing as ever,cheap hair extensions! The adhesive is placed directly on your scalp, and acts as your second skin. One side is stick to your scalp and the other side has hair on it, strand by strand just like your normal hair. An air tight and water tight seal is created to give maximum security. The adhesive needs to be reattached after every 6-8 weeks, as it absorbs oil and perspiration from your scalp and becomes loose. This type of extension is used if you have baby fine hair. The best part is that it can be reused, reapplied, brushed and styled in any way that you want. |
