这段代码编译警告din输入的问题,谁能告速我怎么解决?
library ieee; use ieee.std_logic_1164.all; entity sreg8b is port (clk: in std_logic; load: in std_logic; din: in std_logic_vector(7 downto 0); qb: out std_logic); end sreg8b; architecture behav of sreg8b is signal reg8: std_logic_vector(7 downto 0); begin process (clk,load) begin if clk'event and clk='1' then if load='1' then reg8<=din; else reg8(6 downto 0)<=reg8(7 downto 0); end if; end if; end process; qb<=reg8(0); end behav;
