Help Me! 用的芯片是TMS320VC5509A,开发环境是CCS3.1,仿真器是合众达的SEED XDS510USB2.0,用C语言编写。在开发过程中遇到几个问题,希望大虾不吝赐教。 1. 在CCS3.1 SETUP下,选择C5509A XDS510 Emulator,启动CCS3.1,连接仿真器和目标板时,Messages窗口出现“GEL: Error while executing OnTargetConnect(): memory map prevented write to target memory at 0x0007FE@I/O.”。是什么原因?而在在CCS3.1 SETUP下,选择C5509 XDS510 Emulator,则没出现上述问题。 2. I2C外接AT24C256。DSP工作在MASTER MODE。利用CSL的API函数,初始化I2C模块时,程序如下:
#include <csl.h> #include <csl_chip.h> #include <csl_i2c.h> #include <csl_pll.h>
//---------Global data definition--------- int x=1,y=1,z=1; Uint16 databyte1[7] = {0,0x10,0x11,0x12,0x13,0x14,0x15}; Uint16 datareceive1[6]={0,0,0,0,0,0}; Uint16 databyte2[7] = {0,0x15,0x20,0x21,0x22,0x23,0x24}; Uint16 datareceive2[10]={0,0,0,0,0,0,0,0,0,0}; Uint16 slaveaddressreceive[2]={0,0x10};
// Create and initialize an PLL initialization structure // DSP CLK = 12X24/2 = 144MHz PLL_Config ConfigPLL = { 1, 1, 24, 1 };
// Create and initialize an I2C initialization structure I2C_Setup Init_I2C = {
0, // 7 bit address mode 0x0000, // own address - don't care if master 144, // clkout value (Mhz) 200, // a number between 10 and 400 0, // 8 bits/byte to be received or transmitted 0, // DLB mode on 1 // FREE mode of operation on };
//---------Function prototypes---------
void taskFunc(void);
void delay(void);
//---------main routine---------
void main(void) { CSL_init();
  LL_config(&ConfigPLL); I2C_setup(&Init_I2C);
taskFunc(); while(1); }
void taskFunc(void) { x=I2C_write(databyte1,7,1,0x50,1,30000); y=I2C_write(slaveaddressreceive,2,1,0x50,2,30000); z=I2C_read(datareceive1,5,1,0x50,3,30000,0); I2C_sendStop();
x=I2C_write(databyte2,7,1,0x50,1,30000); y=I2C_write(slaveaddressreceive,2,1,0x50,2,30000); z=I2C_read(datareceive2,10,1,0x50,3,30000,0); I2C_sendStop();
x=1; }
以上程序在调试过程中遇到了2个问题: 1. 当注释掉PLL_config(&ConfigPLL)语句,或将其置于taskFunc()后,则程序能读写AT24C256,反之则不能正确读写; 2. 在能读写AT24C256的情况下,即注释掉PLL_config(&ConfigPLL),第一次写I2C_write(databyte1,7,1,0x50,1,30000)能正确执行,因为I2C_read(datareceive1,5,1,0x50,3,30000,0)能正确读出写进的数据,但第二次写I2C_write(databyte2,7,1,0x50,1,30000)不能正确执行,因为z=I2C_read(datareceive2,10,1,0x50,3,30000,0)不能正确读出写进的数据。当注释掉 y=I2C_write(slaveaddressreceive,2,1,0x50,2,30000); z=I2C_read(datareceive1,5,1,0x50,3,30000,0); I2C_sendStop(); 三条语句时,I2C_read(datareceive2,10,1,0x50,3,30000,0)能正确读出两次写入的数据。似乎I2C_read(datareceive2,10,1,0x50,3,30000,0)有问题,AT24C256输出数据完毕,最后要求MASTER发送NACK信号,I2C_read()没有发。怎样解决该问题?帮帮忙,多谢了!
