DSP设计范例:FIR程序设计(VHDL)[转帖]
-- FIR Digital Filter Design (DSP example)
-- VHDL Data-Flow modeling
-- KEYWORD:
-- generate, array, range, constant and subtype
library IEEE;-- declare the library
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity FIR_filter is
port(rst:instd_logic;
clk:instd_logic;
coef_ld:instd_logic;
start:instd_logic;
o_enable:instd_logic;
bypass:instd_logic;
Xn_in:in std_logic_vector(3 downto 0);
Yn_in:instd_logic_vector(15 downto 0);
Xn_oututstd_logic_vector(3 downto 0);
Yn_oututstd_logic_vector(15 downto 0)
end FIR_filter;
architecture BEH of FIR_filter is
   constant K:integer := 4;-- circuit has four stages
   -- use type and subtype to define the complex signals
   subtype bit4 isstd_logic_vector(3 downto 0);
   subtype bit8 isstd_logic_vector(7 downto 0);
   subtype bit16 isstd_logic_vector(15 downto 0);
   type klx4isarray (K downto 0) of bit4;
   type kx8isarray (K-1 downto 0) of bit8;
   type klx8is      array (K downto 0) of bit8;
   type kx16isarray (K-1 downto 0) of bit16;
   type klx16isarray (K downto 0) of bit16;
   -- define signal in type of arrays
   signalREG1, REG2, COEF: klx4;
   signalMULT8: kx8;
   signalMULT16: kx16;
   signalSUM: klx16;
   signalXn_tmp: bit4;
   signalYn_tmp: bit16;
begin
   -- initialize the first stage
of FIR circuit
   REG2(K)<= Xn_in when (start='1')
else (REG2(K)'range => '0');
   REG1(K) <= (REG1(K)'range => '0');
   SUM(K)  <= Yn_in;
   COEF(K) <= Xn_in;
   -- start the computation, use generate to obtain the
   -- multiple stages
   gen8:for j in K-1 downto 0 generate
       stages:process (rst, clk)
       begin
           if (rst='0') then
       REG1(j) <= (REG1(j)'range => '0');
       REG2(j) <= (REG2(j)'range => '0');
       COEF(j) <= (COEF(j)'range => '0');
       MULT16(j) <= (MULT16(j)'range => '0');
       SUM(j) <= (SUM(j)'range => '0');
   elsif (clk'event and clk ='1') then
       REG1(j) <= REG2(j+1);
       REG2(j) <= REG1(j);
       if (coef_ld = '1') then
           COEF(j) <= COEF(j+1);
         end if;
               MULT8(j) <= signed(REG1(j))*signed(COEF(j));
       MULT16(j)(7 downto 0) <= MULT8(j);
       if (MULT8(j)(7)='0') then
           MULT16(j)(15 downto Smile <= "00000000";
       else
           MULT16(j)(15 downto Smile  <=  "11111111";
       end if;
       SUM(j) <= signed(MULT16(j))+signed(SUM(j+1));
   end if;
       end process;
   end generate;
   -- control the outputs by concurrent statements
   Xn_tmp <= Xn_inwhen bypass = '1' else
REG2(0) when coef_ld = '0' else
COEF(0);
   Yn_tmp <= Yn_inwhen bypass = '1' else
SUM(0);
   Xn_out <= Xn_tmpwhen o_enable = '0' else
(Xn_out'range => 'Z');
   Yn_out <= Yn_tmpwhen o_enable = '0' else
(Yn_out'range => 'Z');
end BEH;
