网上看到的一个问题,没有遇到过,高手给解答一下!我替问题提出者谢谢各位了!
问题提示是: # Model Technology ModelSim SE vlog 5.8b Compiler 2004.01 Jan 26 2004 # ** Error: (vlog-19) Failed to access library 'work' at "./modelsim_work". # No such file or directory. (errno = ENOENT) # ** Error: Library work not found. # ** Error: Verilog Compiler exiting # ** Error: d:/Modeltech_5.8b/win32/vlog failed. # Error in macro ./tb_glr.fdo line 5 # d:/Modeltech_5.8b/win32/vlog failed. # while executing # "vlog glr_jjliu.v # " # Load canceled
我的ini设置是: [Library] std = $MODEL_TECH/../std ieee = $MODEL_TECH/../ieee verilog = $MODEL_TECH/../verilog vital2000 = $MODEL_TECH/../vital2000 std_developerskit = $MODEL_TECH/../std_developerskit synopsys = $MODEL_TECH/../synopsys modelsim_lib = $MODEL_TECH/../modelsim_lib
UNISIMS_VER = d:\Modeltech_5.8b\xilinx_libs\unisims_ver SIMPRIMS_VER = d:\Modeltech_5.8b\xilinx_libs\simprims_ver XILINXCORELIB_VER = d:\Modeltech_5.8b\xilinx_libs\XilinxCoreLib_ver AIM_VER = d:\Modeltech_5.8b\xilinx_libs\abel_ver\aim_ver CPLD_VER = d:\Modeltech_5.8b\xilinx_libs\cpld_ver UNI9000_VER = d:\Modeltech_5.8b\xilinx_libs\uni9000_ver UNISIM = d:\Modeltech_5.8b\xilinx_libs\unisim SIMPRIM = d:\Modeltech_5.8b\xilinx_libs\simprim XILINXCORELIB = d:\Modeltech_5.8b\xilinx_libs\XilinxCoreLib AIM = d:\Modeltech_5.8b\xilinx_libs\abel\aim PLS = d:\Modeltech_5.8b\xilinx_libs\abel\pls CPLD = d:\Modeltech_5.8b\xilinx_libs\cpld work = ./modelsim_work stratix = modelsim_work
不知那位高人可以给予指点,多谢了! |
