我调用了一个DCM,输入输出直接MAP出来。为什么仿真结果倍频出不来,请高手帮帮忙!!!!
难道DCM不能这么用?
输入24MHZ,想出来48MHZ。而且 下图是CLKIN_IN在下降沿时才出来的,上升沿只有LOCK有输出。
上升沿
entity yl is PORT( CLKIN_IN : IN std_logic; CLKIN_IBUFG_OUT : OUT std_logic; CLK0_OUT : OUT std_logic; CLK2X_OUT : OUT std_logic; LOCKED_OUT : OUT std_logic ); end yl;
architecture Behavioral of yl is signal a: std_logic; COMPONENT dcm1   ORT( CLKIN_IN : IN std_logic; CLKIN_IBUFG_OUT : OUT std_logic; CLK0_OUT : OUT std_logic; CLK2X_OUT : OUT std_logic; LOCKED_OUT : OUT std_logic ); END COMPONENT; begin Inst_dcm1: dcm1 PORT MAP( CLKIN_IN =>CLKIN_IN , CLKIN_IBUFG_OUT => CLKIN_IBUFG_OUT , CLK0_OUT => CLK0_OUT, CLK2X_OUT =>a , LOCKED_OUT => LOCKED_OUT ); CLK2X_OUT<=a; end Behavioral;
