What's wrong?
What's wrong?
Test 2345 ,subtest 5, module 3, slot 1 failed.
SRC resistor R806 ,7 & feedback resistor R808 test
Low limit    6.5484800e-01
Result Receiived : 8.7987600e-05 volts
High limit  : 6.798767800e-01
把这张卡换了不就ok 了吗?至于why就让agilent公司去看了,哈哈!
其实地上本没有路,走的人多了也便成了路
This test verifies MOA source and feedback resistors.
So Please check the R806 on the ASRU card . it should be 10k.
