各位,我使用的是TI的5402,CCS是2.2
在Memory map中设置I/O为RAM,在往I/O写数据时,提示: Trouble Reading Target CPU memory: Error 0x80000002/-1058 Fatal Error during: Memory, Device driver: Emulator Controller not responding It is recommended to RESET EMULATOR. This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target. 不知道是什么意思,高人指点指点,谢谢! |
