请问17位的二进制计数器怎么产生?
一个最简单的示例: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity counter17 is port(clk:in std_logic; q:buffer std_logic_vector(16 downto 0) ); end counter17; architecture behave of counter17 is begin process(clk) begin if clk'event and clk='1' then q<=q+1; end if; end process; end behave; 建议你多看看VHDL的书
请问17位的二进制计数器怎么产生?
请问17位的二进制计数器怎么产生?
