程序要完成的功能是在地址1110和11110内写入两个不同的值,然后读出1110的值送LCD显示,看是否能够正确读写SRAM.
事实是CD显示的仍然是要写入11110的值,也就是没有正确写入和读出SRAM的值.
高手改错了!!!
inout [15:0] datbus; output oe; output ce; output we; output lb; output ub; output [17:0] adress;
reg [17:0] r_adress; reg [15:0] r_datbus; reg dat_dir; reg r_oe; reg r_ce; reg r_we; reg [3:0] i; reg [3:0] r_count_clk1; reg ddclk; reg flag; //读写SRAM转换
if(flag) begin dat_dir <= 1; if(r_count_clk1 == 0) begin r_adress <= 18'b00_0000_0000_0000_1110; //SRAM 送地址 r_we <= 1'd0; //write r_ce <= 1'd0; r_oe <= 1'd1; r_datbus <= 16'b0000_0000_0001_1111; //送数据 end else if(r_count_clk1 ==3) begin r_adress <= 18'b00_0000_0000_0001_1110; //送地址 r_datbus <= 16'b0000_0011_1110_0000; //送数据 end else if(r_count_clk1 == 5) begin r_adress = 18'bzz_zzzz_zzzz_zzzz_zzzz; r_oe <= 1; r_we <= 1; end end ////////////////////read////////////////////////////////////////////////////// else begin dat_dir <= 0; if(r_count_clk1 == 0) begin r_adress <= 18'b00_0000_0000_0000_1110; //SRAM 地址 r_oe <= 1'd0; //read r_ce <= 1'd0; r_we <= 1'd1; end else if(r_count_clk1 == 3) begin r_red <= r_datbus & 16'b0000_0000_0001_1111; r_green <= (r_datbus & 16'b0000_0111_1110_0000)>>5; r_blue <= (r_datbus & 16'b1111_1000_0000_0000)>>11; end else if(r_count_clk1 == 5) begin r_adress = 18'bzz_zzzz_zzzz_zzzz_zzzz; r_oe <= 1'd1; //read r_we <= 1'd1; end
end
assign adress = r_adress; assign datbus = dat_dir?r_datbus:16'bzzzz_zzzz_zzzz_zzzz; assign oe = r_oe; assign ce = r_ce; assign we = r_we; assign tclk1 = iclk1; |
