ARM Linux 进程调度(2) FireAngel(原作)
schedule()函数分析:
/* * 'schedule()' is the scheduler function. It's a very simple and nice * scheduler: it's not perfect, but certainly works for most things. * * The goto is "interesting". * * NOTE!! Task 0 is the 'idle' task, which gets called when no other * tasks can run. It can not be killed, and it cannot sleep. The 'state' * information in task[0] is never used. */ asmlinkage void schedule(void) { struct schedule_data * sched_data; struct task_struct *prev, *next, *p; struct list_head *tmp; int this_cpu, c; spin_lock_prefetch(&runqueue_lock); if (!current->active_mm) BUG(); need_resched_back: prev = current; this_cpu = prev->processor; if (unlikely(in_interrupt())) { printk("Scheduling in interrupt"); BUG(); } release_kernel_lock(prev, this_cpu); /* * 'sched_data' is protected by the fact that we can run * only one process per CPU. */ sched_data = & aligned_data[this_cpu].schedule_data; spin_lock_irq(&runqueue_lock); /* move an exhausted RR process to be last.. */ if (unlikely(prev->policy == SCHED_RR)) /* * 如果采用轮转法调度,则重新检查counter是否为0, 若是则将其挂到运行队列的最后 */ if (!prev->counter) { prev->counter = NICE_TO_TICKS(prev->nice); move_last_runqueue(prev); } switch (prev->state) { case TASK_INTERRUPTIBLE: /* * 如果是TASK_INTERRUPTIBLE,并且能够唤醒它的信号已经来临, * 则将状态置为TASK_RUNNING */ if (signal_pending(prev)) { prev->state = TASK_RUNNING; break; } default: del_from_runqueue(prev); case TASK_RUNNING:; } prev->need_resched = 0; /* * this is the scheduler proper: */ |
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!) |
repeat_schedule:
* Default process to select..
next = idle_task(this_cpu);
c = -1000;
list_for_each(tmp, &runqueue_head) {
* 遍历运行队列,查找优先级最高的进程, 优先级最高的进程将获得CPU
p = list_entry(tmp, struct task_struct, run_list);
if (can_schedule(p, this_cpu)) {
* goodness()中,如果是实时进程,则weight = 1000 + p->rt_priority,
* 使实时进程的优先级永远比非实时进程高
int weight = goodness(p, this_cpu, prev->active_mm);
if (weight > c) //注意这里是”>”而不是”>=”,如果权值相同,则先来的先上
c = weight, next = p;
/* Do we need to re-calculate counters? */
if (unlikely(!c)) {
* 如果当前优先级为0,那么整个运行队列中的进程将重新计算优先权
struct task_struct *p;
spin_unlock_irq(&runqueue_lock);
read_lock(&tasklist_lock);
for_each_task(p)
p->counter = (p->counter >> 1) + NICE_TO_TICKS(p->nice);
read_unlock(&tasklist_lock);
goto repeat_schedule;
* from this point on nothing can prevent us from
* switching to the next task, save this fact in sched_data.
sched_data->curr = next;
task_set_cpu(next, this_cpu);
if (unlikely(prev == next)) {
/* We won't go through the normal tail, so do this by hand */
prev->policy &= ~SCHED_YIELD;
goto same_process;
kstat.context_swtch++;
* there are 3 processes which are affected by a context switch:
* prev == .... ==> (last => next)
* It's the 'much more previous' 'prev' that is on next's stack,
* but prev is set to (the just run) 'last' process by switch_to().
* This might sound slightly confusing but makes tons of sense.
prepare_to_switch(); {
struct mm_struct *mm = next->mm;
struct mm_struct *oldmm = prev->active_mm;
if (!mm) { //如果是内核线程的切换,则不做页表处理
if (next->active_mm) BUG();
next->active_mm = oldmm;
atomic_inc(&oldmm->mm_count);
enter_lazy_tlb(oldmm, next, this_cpu);
} else {
if (next->active_mm != mm) BUG();
switch_mm(oldmm, mm, next, this_cpu); //如果是用户进程,切换页表
if (!prev->mm) {
prev->active_mm = NULL;
mmdrop(oldmm);
* This just switches the register state and the stack.
switch_to(prev, next, prev);
__schedule_tail(prev);
same_process:
reacquire_kernel_lock(current);
if (current->need_resched)
goto need_resched_back;
return;
