中断的老问题?
中断的老问题?
nios的外部中断,按下按键对应的LED 点亮,为什么不行呢?高手帮忙给看看
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "alt_types.h"
#include "sys/alt_irq.h"
volatile int   data;
int main (void) __attribute__ ((weak, alias ("alt_main")));
   * Use alt_main as entry point for this free-standing application
void delay1000ms(alt_u32 time)
   alt_u32 i ;
   for(i=0;i<time;i++);
static void handle_button_interrupts(void* context, alt_u32 id)
  volatile int* edge_capture_ptr = (volatile int*) context;
  *edge_capture_ptr =  IORD_ALTERA_AVALON_PIO_EDGE_CAP(KEY_RISING_PIO_BASE);
  IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_RISING_PIO_BASE, 0);
static void init_button_pio( void )
  void* edge_capture_ptr = (void*) &data;
  IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_RISING_PIO_BASE, 0xf);
  IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_RISING_PIO_BASE, 0x0);
  alt_irq_register( KEY_RISING_PIO_IRQ, edge_capture_ptr, handle_button_interrupts );
int alt_main (void)
  int last_tested ;
  last_tested = 0xffff;
  data = 0x0000;
  init_button_pio();
  IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x01);
  delay1000ms(200000);
  IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x02);
  IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x04);
  IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x08);
  IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x00);
    while(1)
      if (last_tested == data)
        continue;
      else
        last_tested = data;
        switch (data)
          case 0x0001:
            break;
          case 0x0002:
            break;
          case 0x0004:
            break;
          case 0x0008:
            break;
  return 0;
你用main去操作,不要用alt_main.
在交流中前进,共同实现nios的应用。
恩!果然对了,那alt_main()和普通的main()有什么不同呢?我用了main()以后ram 不够用添加了SDRAM才搞定
