关于fifo的问题,请高人指点!谢谢~~
哪位高人有fifo的VHDL代码阿?实际烧到片子里能运行通过的!
我是新手,在网上看到一些代码,都不太对,需要修改,我自己参考着编了一个,仿真通过,但还是烧到片子里不能运行,无输出,希望哪位高人指点一下!给我一个验证过的完全正确的代码让我参考一下!谢谢了,好长时间都没解决,非常郁闷!
我把我的代码附在这里,同时希望批评指正!
library ieee;
use ieee.std_logic_1164.all;
entity fifo is
port
clkwr,clkrd,wr,rd,cs:in std_logic;
din :in std_logic_vector( 0 to 7);
dout ut std_logic_vector( 0 to 7);
full,empty ut std_logic
end fifo;
architecture fifo_arch of fifo is
type memory is array (0 to 3) of std_logic_vector( 0 to 7);
signal ram:memory;
signal wp: integer range 0 to 7 :=0;
signal rp: integer range 0 to 7 :=0;
signal in_full,in_empty:std_logic;
begin
process(clkwr,cs)      -----------------------------------------write
begin
if rising_edge(clkwr) and cs='0' then
if (wr='0' and in_full='0') then
ram(wp)<=din;
end if;
end if;
end process;
process(clkrd)      -----------------------------------------read
begin
if rising_edge(clkrd) and cs='0' then
if (rd='0' and in_empty='0') then
dout<=ram(rp);
else
dout<="ZZZZZZZZ";
end if;
end if;
end process;
process(clkwr)     -----------------------------------------write hand
begin
if(wp=3) then
wp<=0;
else wp<=wp+1;
end if;
end if;
end if;
end process;
process(clkrd)  ------------------------------------------------read hand
begin
if(rp=3) then
rp<=0;
else rp<=rp+1;
end if;
end if;
end if;
end process;
process(clkrd)    -------------------------------------------------empty
begin
if falling_edge(clkrd) and cs='0' then
if ((wp=rp) or (wp=rp+1) or ((wp=0) and (rp=3)))then
in_empty<='1';
else
in_empty<='0';
end if;
end if;
end process;
process(clkwr)        --------------------------------------------------full
begin
if falling_edge(clkwr) and cs='0' then
if ((rp=wp+1)or  ((wp=3) and (rp=0))) then
in_full<='1';
else
in_full<='0';
end if;
end if;
end process;
full<=in_full;
empty<=in_empty;
end fifo_arch;
为什么没人帮我呢???急啊!
为什么不直接调用IP核?
谢谢二位,最开始时,我想自己写一个!后来不行,还是调用ip核了!
但我就是不太明白,代码问题出在哪里!功能仿真过,时序仿真通不过!
不是,烧到片子里也不行!肯定是代码的问题!
谢谢,我的速度并不高啊!才几十k,肯定是代码有问题,但找不出原因,不过最近不管它了,先弄别的,我用ip核暂时替代了!
我不是高手
